Trader Rating: (-1)
![]() Feedback Score: -1 reviews
I am doing a Huge Garage clean out to fund a new project. All parts are is great/amazing condition and in perfect working order. I have lost of ka24de parts if you see anything not listed you need PM me and I most likely have it. Everything is OBO and I will part out the RB25DET if a couple people want parts.
S14 KA24DE Parts : Block bored and honed for 90mm pistons ready for build - $200 : Completely rebuild cylinder head with new cams. Complete head - $250 : New full gasket kit oil pan to valve cover - $40 : New set of std. Bore pistons,rings and wrist pins - $80 : New full timing kit with chains, guides, gears everything - $80 : New set of std. Rod and main bearings - $50 : Set of good used std. pistons perfect condition - $25 : Oil pan - $20 : Alternator - $20 : Short shifter - $25 : Valve cover - $20 : Complete Intake Mani - $20 : 2 Crank griddles - $10 each : 2 Good oil pump front covers with oil pickup - $10 each : 2 front timing covers - $10 each : Power steering pump complete with hard lines and res. - $30 a lot more stock ka parts if you need anything just ask. S13 RedTop SR20DET : Valve cover - $40 : Obx oil filter relocation kit - $30 Now onto the Built RB25DET I basically have a full s14 swap the only thing missing is turbo and injectors. Have complete motor, rb25 tranny, stage 3 clutch, rb25 to s14 1piece driveshaft, rb25 to s14 wire harness, and stock rb25det ecu. Here are the motor specs all have 0 miles accept for used rb25det cams that were put in. If I do part out I would like to keep the shortblock/bottom end assembled. RB25DET $2,800 OBO or will part out. : RB26DETT Crank, Rods, and Pistons : ACL Race bearings : ARP rod bolts : ARP head bolts : Stock head gasket : Completely rebuilt per head : Powder coated white valve covers : Isis Intake Mani powder coated white to match valve covers : Custom billet fuel rail made to match valve cover design : CX racing billet q45 80mm throttle body : New water pump : New timing belt and tensioner : RB25DET used cams : No name tip mount exhaust mani : HKS hi-power exhaust : RB25DET rwd Tranny : Stage 3 clutch bought with 3 dyno runs on it haven't used it yet. Last edited by Sidewaysallthetime; 02-09-2016 at 09:55 AM.. Reason: sold |
| block, ka24de, pistons, rb25det, swap |
