![]() Join Date: Jun 2008
SOLDMoroso Nissan SR20DET Large Capacity Aluminum Oil Pan. RETAIL $250, Greddy Large Capacity Aluminum Oil Pan is $350, I'm selling this for $150!!
Bolts perfectly on to any SR20, will never leak!! Just be sure to know how to use liquid gasket. It is all sheet aluminum press bent and welded. Also features a magnetic oil drain plug. All hardware is supplied with this for flawless install. There are 2 hinged baffles to allow for proper oil supply to the pickup when corning hard or drifting. The Moroso pan also allows for 4.75qts of oil to be used. ![]()
F/S Moroso SR20 Oil Pan & Solid Mounts Last edited by Stratokat; 03-03-2011 at 09:43 PM.. |
| moroso, oil pan, oilpan, sr20, sr20det |
