01-28-2012, 07:50 PM | #1 |
Does this 5lug conversion work with my s13?
Hello everyone, so I have a s13 hatchback on TEIN FLEX coilovers made for the s13, I'm planning to do a 5lug, and will this set be compatible with the coilovers?
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices Sorry, still learning Thanks |
01-28-2012, 08:51 PM | #2 |
jesus christ! why would you pay that much that on ebay?
if you really wanna pay that much, why not just go to nissan and buy the parts directly from them? or this: Attain KS-740 Front 5 Lug Hub Conversion S13 (Pressed in 40mm studs)
BustedS13: anything you can hide on your person is free. junkyard law. |
01-28-2012, 09:00 PM | #3 |
Hot Damn That's pricey!!! Question is do you really need brand new knuckles and lca's??? You can cut the price in half by going ichiba 5 lug conversion bro... if your ball joints are worn you can just replace those.
http://www.frsport.com/Ichiba-Front-...SX_p_7818.html people might/may argue about these but let ME tell ya they are fine there's a lot guys here in AZ that run them and never had any problems what so ever, matter of fact just helped my buddy install them on his coupe a few months back and he drives/drifts the shit out of his car. |
01-28-2012, 10:14 PM | #6 |
Thanks for the recommendations guys, I do not actually plan on buying this set, but I do have connects to these exact items; I just need to know if it's compatible with the Tein flex coils that's all.
I kinda do want new parts rather than used parts, what you guys think? |
01-29-2012, 09:45 PM | #8 |
"New in Box! Factory JDM OEM Parts!
This Kit includes everything needed to install 5 Lug Wheel Hubs on your 1989-1994 NISSAN 240SX with 4 Lugs! This kit fits any S13. 180SX / 240SX / SILVIA." Quote from the ebay listing, I highlighted the important parts for you cause you missed it the first time.
01-29-2012, 10:07 PM | #9 | |
Trader Rating: (38)
Feedback Score: 38 reviews
So as an alternative (to new coilovers or lower mounts), you would need a bolt "sleeve" for the S13 bolt to fit the S14 knuckle. |
01-30-2012, 01:55 AM | #10 |
S14 strut to knuckle bolts are 14mm diameter, S13 ones are 12mm. You can get 1mm sleeve from ebay (i bought mine there, 1mm thick 12mm ID tube, less than 3$ for 1ft) . Or you can redrill your strut and use S14 bolts.
If you use S14 front spindles, you NEED S14 lower ball joint too. Thus most people just use S14 front lower arms. Beware as they are 8mm longer each than S13 ones, so make sure your steering tie rods are adjustable AND long enough. Or buy another set. Or use S14 ones. Your choice. Dont forget you need 5lugs brake discs too ... |
