![]() Join Date: Mar 2005
Trader Rating: (41)
Yes, it'll work with your z caliper setup, but it all depends on how you did your five lug. Did you use s14 hubs or did you go with icheapa, or something else for s13 spindles? You've gotta use s14 hubs with these. Great price Shane!
"cigarettes killed my father, and raped my mother!" |
This is for s13 wanting to run s14 spindles/arms when doing 5lug swaps. Straight bolt on for 350z brakes as well. The 350z uses 14mm bolts for the caliper to spindle, unlike the 12mm stock. Is the z32 hardware 14mm...not thinking so.
When I had these on my s13 I ran the 350z brakes in front and J30 rears with hydro brake...awsome! |
