Please Help with S14 SR Turbo Lines
Could someone tell me or post pictures of S14 sr20det turbo lines from the turbo to the motor, 2 oil and 1 coolant lines? thanks alot.
Corey |
![]() Join Date: Jan 2005
Pics would be great as I am on the same boat. The FSM is not very clear when it comes to this. I have the Taka lines and I only find 1 14mm opening. On the FSM it looks like the other one would be by the upper radiator hose outlet, but there is nothing there. Here is the best pic I have for the moment.
Thank you. |
That last one is for an S13. Doea ANYONE have a pic of the taka lines on an s14. Actually let it be any type of lines, even stock will help. Thank you.
Carlos |
The other line mounts to the upper radiator hose fitting,you won't see it if you don't have the elbow [coolant] on
I don't have a digital or I'd take a pic for you Hope that helps Jerry |
I found the f*&%er today. The previous owner plugged it with JB weld. The first pic from phase 2 that I posted is correct. Just the third line goes to the on the radiatior hose outlet itself.
#9 | |
