![]() Join Date: Dec 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
whats a good substitute for eccentric bolts
Yeah thats right you know they slip...
I been through a bunch of alignments allready and want to make the next one the last one for a while including cornerweighting. I have coilovers and all adjustable arms other than lower control arms. What can I use instead of the eccentric bolts for the toe arms and rucas? |
![]() Join Date: May 2002
no i wont waste my time on such
dont realy care never had problems w/ the eccentric bolts..ever. new subby goes on, just powder coated, no solid bushings this time i like spacers |
![]() Join Date: Sep 2003
heh..i just pressed in my solid bushings...rides better on the freeway. shocks doing their job instead of waiting for rubber to compress.
You're the only person i've ever heard not having a problem with the bolts backing out. I suppose i could use thread locker . Are you suppose to?
Hi |
no im not
i just tighten the hell out of them no air tools muscle baby muscle! and how do i know its ok? because ill get an alignment front adn rear then do a few events and daily driven ...about 3 months get another alignment rear still same, SLIGHTLY out of spec but nothing like a bolt slipped/turned |
Or just use a fender washer, a little less work than welding one on.
I've only had problems with monkeys overtightening them which spins the washer and locks it into the bolt. Then you have to drop the subframe just to hammer the bastard out.
#9 | |
fender washer?
Got them out withough dropping the frame though |
