HELP PLEASE wiring problem (rb20det into s13)
I was soldering, burned my hand, then slipped and i think i yanked this wire loose. its brown with silver dots and it is coming out of the passengers side relay box. from the picture i took before you can see it heading towards the alternator. there is also a small ground wire spliced into the alternator ground that is going nowhere as well.
