![]() Join Date: Feb 2002
Enjuku Racing - A1 Tech H11 Head Studs - SR20DET
A1 Technologies H11 Head Studs - Nissan SR20DET
http://www.enjukuracing.com/products...n-sr20det.html ![]() ![]() http://www.enjukuracing.com/products...n-sr20det.html Product Description A1 Technologies H11 Head Studs - Nissan SR20DET If you're looking to make big power but don't like the idea of lifting your cylinder head and replacing head gaskets frequently these are exactly what you need! These studs are manufactured by A1 Technologies and utilize an H11 material that is much stronger than the typical 8740 chromoly and yields a tensile strength of 260,000 psi. They are also provisioned with a hex broach on the top of the stud enabling you to install them with the cylinder head on the car if necessary. What is so different about these head studs? These Head Studs include an additional feature known as a "dog point" that seats the stud in the block and preloads the fastener for an accurate and repeatable torque sequence.
![]() Join Date: Aug 2011
These appear to completely bottom out on the block.
They look nice, but I wonder if many people have used these on SR motors, it would be nice to see some review of this product. Price seems a bit on the high side, should be very good quality I assume. |
These don't sell as much as the ARP's, which is probably why you don't see many reviews on them. A1 claims that these are the absolute strongest studs available on the market. Their studs are manufactured from H-11 tool steel with a tensile strength of 260,000 PSI vs. ARP's 200,000 PSI rated 8740 Chromemoly Steel studs. Most people go with the ARP's because the price point and they have been proven to be the "go to" studs for many years now. However, if you are looking for maximum performance and the strongest studs available for the SR20, then the A1's are the studs you want.
Info states that these can be installed with the head still on the car, I assume they meant to say on the block.
Not sure if it can do that with ARP studs? I might be doing head stud upgrade soon, these seem to be of interest to me as I don't want to remove the head from the block. Thanks for sharing these. |
