![]() Join Date: Oct 2008
SR20DET Mines 62 ECU, What Is The Tune????
Ok so i have an sr20det mines 62 ecu, but what it is the tune on it? Does anyone out there actually know the tune to these things because i have 550cc injectors that are not installed yet because i need an ecu upgrade, or at least i think i do.
If theres anyone out there that know what the specs on these things are, please help!!!!!! |
#2 | |
![]() Join Date: Jul 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
its just a generic tune with speed limiter removed and a little richer up top. Its for a stock SR20 setup with bolt ons and higher boost.
HouseBuyers365.com Quote:
#3 | |
![]() Join Date: Jul 2008
i have the same thing as well as a tomei ecu...they both just collect dust.
![]() Quote:
Ok well i have a Z32 MAF and 550CC injectors so it does me no good i need a Power FC, Im going to just sell it......Can some1 go ahead and close up this thread...thank you.
Well if it is tuned then you already have the socket soldered in for a daughterboard.
Why not get nistune or contact steve shadows for a tune. Then you just install the daughterboard and should be good to go with the z32 and 550's. |
