![]() Join Date: Feb 2002
*NOW IN STOCK* Price: $889.99
![]() ________________________________________ The T-TRAX ADVANCE “is the most effective LSD unit available” & has the best overall advantage in comparison with the other aftermarket products available today. Amazing penetrating angles at the time of Drift, with such persistence in the accuracy of line taking and all aspects of cornering, the T-TRAX ADVANCE shows amazing efficiency with the aggressive cam angles which is optimum for drifting the friction clutch discs also has a larger surface area, furthermore with the use of the coil spring discs and the high setting of initial torque which is raised higher than any other brands in the market today. With a total effective friction area of 764cm^2 throughout a number of oversized clutch discs, the Tomei Technical Trax has the largest friction area of any other differential on the market. Tomei's Technical Trax has these features over its competitors: *Torque Conductivity *Quick Response *Heatproof *High Durability *Easy Maintenance __________________________________________ Click here to order ===> http://www.enjukuracing.com/products...san-240sx.html
