#91 | |
#93 | |
I'm really getting to like those SportMax wheels. ![]() Will they clear front 30mm Z32 calipers?
SOLD: 91 240SX Coupe SR20DET, 05 Evolution 8 NEW: 08 Evoluton 10 |
#94 |
![]() Join Date: Mar 2005
Let's not forget about the good old Buddy Club P1 / Kosei K1
You could probably get away with a 17 x 9 +27 with a 10mm spacer. Decent offset for 4 lug, good brake clearance. http://www.first-inc.co.jp/buddyclub/p1r/p1lup.html
A SPEC PRODUCTS CORP AME Wheels, Advan, ARC, Gram Lights, Nardi, Personal, Recaro, Works Bell, Work Wheels, Volk Racing, 5Zigen, & more! 626.618.1100 x 103 / aim: aspectuan Advertiser's Specials! Read / Give Feedback! Please Rate Us!
#96 | |
#97 | |
anyways, those are the wheels i LOVE on an S13, they look perfect. i didnt buy any b/c i got my nismos. they are 17x9+38 in back, and they sit perfectly flush. they almost stick out a little bit. i dialed in a little more camber so they wouldnt rub either. so a 17x9 +27 with 10 mm spacer will need a hella fender pull, fender flare, or mad tyte camber. some of you guys go way to extreme on these offsets. 17x8 +33, 17x9 +38 fit EXCELLENT.
![]() HighTach Motorsports |
#99 | |
If you like that style, try to see if Luke @ Tirerack is still doing that custom drilled Kosei K1 offer.
#100 |
OK guys... i got my tires today and put the wheels on. Now that they are my car, here is what I can tell you:
1. Fronts did not clear my coilovers. Needed a 6mm spacer. 2. Wheels sit FLUSH despite 35 offset 3. Rear fenders will need to be pulled if I want to lower my car anymore(which I do, so I will) I am running 225/40's in the front and 265/40's in the rear. I went in thinking I was going to run 225's all around, but when they put the 225/40 on the rears(9.5"), it did not look good. Then we slapped on a 265/40 and it looks sweet. I am also running camber in the back, not sure how much, but a decent amount. My buddy is bringing my digi-cam back right now so I will snap some pics in about an hour. |
#102 |
wow thats a horrible pic of the wheels haha
the P1's are discontinued?? damn. I got some P1s in 16" last year from http://www.aj-racing.com/ |
#103 | |
![]() Join Date: Nov 2004
#110 | |
#111 | |
´¨) ¸.·´¸.·´¨) ¸.·´¨) (¸.·´ (¸.·´ .·´¨¨°º3 stArRº°¨¨°º
#114 |
My ce28n volks on my old 240. 17x7.5 +25 F and 17x8.5 +30 R. If I had to do it again, I would have ordered 17x8.5 all around and used a spacer. Oh well. I'm just going to use these on my new daily driven s13 (unless someone wants to give me close to what I payed for them) The blue 240 now rolls around on enkei rp01s Johann |
#115 |
ive got the lamer version of the buddyclubs the P1 RacingII...
17X7.5+42 offset(i think?) running 225/45 17's ![]()
S13 coupe w/ Silvia front end conversion S14 240SX (dead) |
