![]() Join Date: Jul 2003
Trader Rating: (128)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 128 reviews
bump back up for sale
also going to be parting out the motor shortly Long block $5500 = block / head / cams / valves Turbos $1400 valve covers $350 Intake manifold with butterfly's and injectors $650 Alt/starter/ps/ac $500 nuts bolts mounts / brackets. gear box comes with all drive shafts axles and attessa system $5500 (6sp Getrag) Brembo's / sub frames / suspension / mounts. |
Do you have coilpacks? Please PM if you do.
www.illgarage.com |
![]() they are seires 2 ones that are have the internal coils so if you have the mitsubishi CAS they will not work but if you have the HITACHI CAS - they will work. sold them. sorry. I have the R34 turbos for sale |
#23 |
parting out an R33 RB26DETT
Heads with cams and intake Short block with pistons and crank. oil pan assembly cam covers and coil pack cover harness ecu ignitor. |
