Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 12-10-2010, 04:06 PM   #1
koukisandsomeapplejuice
koukisandsomeapplejuice's Avatar
koukisandsomeapplejuice is an unknown quantity at this point
Thumbs down My z32 wont go into gear
My car wont go into gear
Replaced the slave and master.. nothing.. in order to move the car i have to start it in gear and rev match the others clutch less.. other thn that it drives fine.. no noises.. nothing.. clutch is still stiff.. no leaks.. just isnt working.. help anyone?
koukisandsomeapplejuice is offline   Reply With Quote
Old 12-10-2010, 04:25 PM   #2
Thumbs down Wont go into gear! Help!
ok so my 300zx wont go into gear anymore.. i replaced the master and slave.. nothing.. no leaks no noise.. only way to move the car is by starting it in gear and rev matching to change gears.. runs fine other thn that.. its also a stage 2 clutch on a stock NA motor.. doubt the clutch broke but who knows.. Can anyone help me??
Old 12-10-2010, 04:28 PM   #3
Josh
Josh's Avatar
Josh has a spectacular aura aboutJosh has a spectacular aura aboutJosh has a spectacular aura aboutJosh has a spectacular aura aboutJosh has a spectacular aura aboutJosh has a spectacular aura about
if the master is actually moving the slave and the clutch is actually being disengaged, it is your linkage
Josh is offline   Reply With Quote
Old 12-10-2010, 04:38 PM   #4
$nicklefritz
$nicklefritz's Avatar
$nicklefritz is an unknown quantity at this point
bleed it again make sure you dont have air in the system if tha doesnt work check the clutch pedal for correct clearence
VUIL-GEBOOSTED GANG$TA
$nicklefritz is offline   Reply With Quote
Old 12-10-2010, 04:44 PM   #5
s13dan
s13dan's Avatar
s13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enough
Do you have pedal pressure?
89 240sx hatch #933-the hot rod
91 240sx coupe #131,603-the daily
s13dan is offline   Reply With Quote
Old 12-10-2010, 04:47 PM   #6
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
would it go into gear BEFORE you replaced the master and slave?
to me it sounds like its not bled out fully and isn't disengaging when you press the pedal down.
Old 12-10-2010, 04:52 PM   #7
1on1
1on1's Avatar
probably need a new clutch.
two of my friends had the same exact problem. they pulled out their clutch and the spring on the clutch came out.
try and bleed it again, if all else fails, check your clutch.
instagram
Old 12-10-2010, 05:13 PM   #8
Hey.. i bled it twice replacing both cylinders.. clutch has plenty of spring in it.. doesnt feel different at all from before whatever broke..
Old 12-10-2010, 05:15 PM   #9
Forge_55b
Forge_55b will become famous soon enoughForge_55b will become famous soon enoughForge_55b will become famous soon enoughForge_55b will become famous soon enoughForge_55b will become famous soon enough
change out your tranny fluid as well as everything else above
Forge_55b is offline   Reply With Quote
Old 12-10-2010, 05:21 PM   #10
damn ill try.. imma put it on a friends lift cos its way to cold to do in the outdoors here in ny and drop the tranny =\.. should have bought a 240
Old 12-10-2010, 05:46 PM   #11
lysticalz
lysticalz is an unknown quantity at this point
same thing happened to me last year. pulled the clutch out. seems that one of the springs popped out and was wedged between the clutch and pressure plate.
lysticalz is offline   Reply With Quote
Old 12-10-2010, 05:47 PM   #12
1on1
1on1's Avatar
dont know why, but that's usually what happens.
instagram
Old 12-13-2010, 10:10 PM   #13
damn.. im on a budget.. how much did you end up spending?
Old 12-14-2010, 09:21 AM   #14
adamvann3
adamvann3's Avatar
adamvann3 is an unknown quantity at this point
Where did you get your master from. I have read on more than one occasion that autozone, advanced master cylinders have been faulty out of the box and it has taken 3-4 exchanges before a good one is had. Normally has to deal with improper or cracked seals.
88ss 368
adamvann3 is offline   Reply With Quote
Old 12-15-2010, 07:55 AM   #15
Corbic
Corbic's Avatar
240s can have the same issue, mine lost the master 3yrs ago, replaced both, ditched the damper as well.
Was anything else wring with the trans? Weak clutch, chattering throwout bearing? Did you adjust the clutch pedal or linkage at all?
Old 01-14-2011, 08:21 PM   #16
well i fixed the problem.. clutch spring popped out and got jammed,.. man z32's are a pain to work on but i just ordered a complete clutch kit and i was good to go.. to bad i was just involved in a hit and run -__- so now i need a new fender, got one coming in tuesday, the money pit never fills!
