![]() Join Date: Jul 2008
Garrett t25 with stock manifold external wastegate
hey guys just took this set up off my car a week ago. i was gonna go bigger turbo with this manifold but decided to use an internal wastegate set up instead. the turbo has the wastegate welded shut and there are no leaks in any of the welds. comes with an o2 sensor, water and oil lines (no return tho). it has a legit tial 38mm wastegate with a dump tube. the turbo has no shaft play and pushes great. didnt have a boost controller so i just ran off the spring which is 7lbs i believe. this is a great setup for someone who wants an external wastegate when they go bigger turbo as well. i like the stock manifolds the best because they keep the heat in better. some argue otherwise but w.e. not here to discuss that. i also included a clip here as well to show it has no shaft play. throw me a decent offer and ill consider it. no lowballers pleeeeeease.
video clip Picture222.flv - Video - Photobucket - Video and Image Hosting pm me for more info |
![]() Join Date: Aug 2006
Trader Rating: (24)
![]() ![]() Feedback Score: 24 reviews
I'm interested in the turbo. What would you be looking to get for it? I wouldn't need the exhaust housing since its welded, if that would change anything....
manifold, wastegate w/ dump tube sold...have a turbo left with a welded wastegate (lines are gone) still has 02 sensor (skinny) and exhaust elbow...any offers? pm me
