![]() Join Date: Apr 2003
Trader Rating: (33)
90-94 q45 LSD (3.54) 6-bolt star style
If anyone can get their hands on the lsd listed above please email me at [email protected]. I need this to complete my new LSD setup.
I have a 5-bolt star style Q45 LSD (3.69) that I would be willing to trade. I will try and get pix up by tomorrow night. This 3.69 LSD works with 92-94 J30 axles. |
![]() Join Date: Nov 2009
There is one at a yard near me but im in florida. Whats it worth to ya?
Wheels in sig pic forsale. Rear 18x12.5 - 12 fronts are 18x10.5 - 10.
Trader Rating: (33)
I believe all 90-94 Q45 have the same 3.54 and yes they are all VLSD. You would have to split apart the housing to tell the difference between the different gear ratio's that are offered but from my research I should be good with the 90-94 Diff. I do also believe 97-01 Q45 diffs have a 5-bolt star configuration where as the 90-94 have a 6-star bolt pattern used with the larger spline axles.
pm your number ...
il send you a text tomorrow when I'm at the junkyard to make sure you want it, when I find it.... |
Trader Rating: (33)
Also, I might be able to use the 90-96 Output Shafts off the q45 to swap onto the diff I have now so if anyone finds these i would be willing to buy them and take a shot at it and find out if I can actually do this. 3.69 ratio with 31 spline axles would be awesome.
Thanks again. |
