#271 |
![]() Join Date: Jun 2007
Here's whats wrong with my fleet.
240sx -one of my pop ups wont pop up -needs a new radiator fan -gas gauge doesn't work mr2 -stalls randomly -steering wheel falling apart -drivers seat falling apart -clear coat on front bumper peeling up -missing some wheel studs corolla -been off the road for 15 years, so everything volvo 1 -needs new tie rods -blower motor broken -needs a new downpipe volvo 2 -needs a transmission put in -missing an important bolt in the rear suspension -needs new tires volvo 3 -needs a new ecu -needs battery |
#272 |
![]() Join Date: Aug 2010
Trader Rating: (38)
need to replace my rack and pinion_______ (just bought it, waiting to get it in the mail)
pass side window is loose_________ wabbles a lil when rolling down needs new slide pin for rear break needs paint job bad needs driver side fender ________ mines dented. thx sis. tach needle dances sometimes needs new tires/wheels might need to reseal valve cover needs new shift boot/trim needs new stereo driver side lock doesnt lock from inside bad exhaust leak semi-bad syncro in tranny for 2nd gear mostly cosmetic stuff. or minor things. |
#273 |
same damn problem. For a second i thought it could have been my heater core, but after rerouting i still get water in there.
#275 |
![]() Join Date: May 2010
lol i thought my 240 was wack
blown motor single cam (dropping a ka24de-t wit taxes) leaks water in front window and sunroof need clutch! low as fack hate speed bumps oil lecks from who kno where missing/broken button everywhere rug stain up like crazy needs paint (chalk paint all over) pop up light motor dont work front end is chet blown coils in back (coil or spring hit and make car jump to the side) front sway bar bend old school momo steering wheel ripped needs bodywork holes in hatch (se wing removel) (stupid rain) goes on and on and on but i love it!!!!!!! |
#276 |
![]() Join Date: Jul 2009
fastback = needs paint, need additional parts to complete motor upgrade.
vert = needs silvia front put on and paint whole car and finish vq swap corolla gts = pos crap ghetto rigged woodscrew in place of bolts turd |
#277 |
My s13....
Broken sun roof latch Seats torn, passenger seat has metal sticking out so it burns the arm in the summer eff passengersWhen it rains and I drive, turn, stop..sit inside, I get showered by cold water from the sun roof. Who designs a car with no cup holders. Ftw I take out the ash trap and BAM. CUP HOLDER. Fear of being burned alive when it over heats Currently no engine. And still better than any car I've laid eyes on<3 grew up with is car since day 1 I was born. Kinda like an older brother to me I suppose. |
#279 |
![]() Join Date: Mar 2010
Location: Back IN FL, bring nice cars to the fail state!
09 WRX
Needs new pads at 20K miles and 2 years old....sigh 07 Frontier Needs new pads at 50K miles....towing the 240 to MD took alot of life out 91 240 (aka the money pit) Interior ECU and supporting shit (sold standalone) Paint Job |
#281 |
![]() Join Date: Mar 2007
03 z
-battery terminal is loose somehow and can't be tightened. temporarily zip-tied it till i can get a new battery. -cd player doesn't work -navi randomly goes on and off or says "disc error" or "wrong software type" -passenger window doesn't work 80% of the time -exhaust pipe is smashed/scraped to hell -some bolts on the underside are ground down -front bumper/lip paint is fucked -corner of the front bumper is cracked from the tire hitting it all the time -it's too low
#282 |
fmic is beat to hell/leaks ridiculously
timing is off because of boost leak intake manifold is also leaking.. dont know where. no bumper support.. its winter.. bumper falls off every other day and my bumper lights blow up every time it happens. body kit is beat to shit.. not in a good way either, it just wont fucking stay on the car radiator is leaking.. efan is ghetto and held up by zipties rad hoses leak even after i went and bought new ones (wtf??) clutch is on its way out wheels are fucked up, one of them is bent apparently rust is starting to take over my frame rails found out my car was in a collision with something (rad support fucked up behind headlight, CLEANEST carfax i've ever seen in my life. both fenders are fucked from the lack of bumper support.. the bumper takes the fenders with it wherever it goes (or doesn't go..) side mirror was knocked off in a parking lot ![]() paint looks like doo doo. and thats just the stuff wrong with it today.. tomorrows another day. |
#283 |
Heh... FML!!!
240sx Cracked dash Driver window doesn't work Mismatched rims Ignition switch Rattle can paint PS leak Clutch is going bad Timing is a bit off (I'll fix it on Wednesday) Leaking coolant (I have no idea where.) Retarded ass headlights (I'm signaling batman and shit) Dented rear lower 1/4 panel Cracked lip Cracked bumper Cressida: Stripped wheel stud Automatic Small coolant leak from reservoir Paint/clear coat fading Rusty spot in hood. Dings here and there I think that's it...
Hachiroku, ATTACK! ATTACK! ATTACK!!! |
#284 |
S13
Radio keeps blowing fuses. Tried to figure out the problem, looked for shorts, bad wires, loose connections, etc. Can't seem to find out why. SR running rich Smell gas everywhere Tach doesn't work Speedo doesn't work It's a mad headache! |
#285 |
S13
-needs camber plates to much poke going on... -needs alignment -need new turbo gaskets -needs new test pipe/downpipe -needs new wideband sensor -needs new flex a lite fan -needs new brakes -needs new brake master _NEEDS to never daily this car through winter again.
http://www.leg1t.com |
#287 |
![]() Join Date: Apr 2010
S14
trunk is slightly loose, rattles alot like 7 front studs and bolts are a little stripped and 1 stud is very bent need new front pads need to re-bleed rear brakes need fan shroud (fit with koyo rad and aem intake?) need some freon for moar baller a/c i stripped rubber drainer for my radiator, so have to unhook lower hose to drain it lol paint slightly faded very slight oil leak, still havnt figured out where its coming from (planning on a rebuild anyway) low compression in cylinder 3 86 bmw 528e doesnt run and still dont know why - may be main relay sensors 99 eclipse gs needs new motor or rebuild need new brakes all around body kit is kinda falling apart |
#288 |
![]() Join Date: Sep 2005
Trader Rating: (48)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 48 reviews
My driverside window switch will unlock the doors but wont lock them...
Split seem in my drivers seat and rear seat at the top center portion(go figure its leather....) No p/s fender liner A few random creeks and clunks... NO FUCKING CLUE.... And my cel will come on for a few min every once in a while... AND ITS STILL AUTO- I have a 100% complete 5 speed swap I bought when I first got the car. I was then deployed and bought a complete s14 sr swap. Motor is having a few delays from the shop... So I could do my five speed swap and rock it for a few weeks/months and then have to turn around and do it again... or just wait and be patient until I get my motor back from black traxx... Any Ideas ???
![]() Do you suffer from vaginal dryness... |
