clutch safety switch
Ok my dumb ass attempted to start my car without pushing in the clutch, now my car wont even start. Everything electrical works ;radio, lights, seatbelt, etc. just the engine wont start. i just hear one click under the dash by the clutch pedal where the clutch safety switch is. I need to know how to fix that so i can drive my car again. Please help!!!
bypass it.
weird how did that happen tho. if u try to start the car while not pushing clutch it doesnt do jack. take teh 2 wires from the switch and put a jumper cable now you can try to start your car with out pushing in clutch. a lil bit dangerous if your car is in gear. if that works then its forshure your switch.
fS! vlsd ! slim fans ! hid kits ! lug nuts ! #/f/search.php?d...earchuser=bo2o ^^^click^^^ |
Its pretty much near your oil filter. If you are standing on the passenger side, its the big round thing next to it on your left (towards the EGR valve). Hopefully someone has pictures so they can show you where it is. It's impossible to miss.
![]() Join Date: Oct 2007
Trader Rating: (53)
starting the car without pushing in the clutch wont do anything...
did you start it without the clutch while it was in gear? if thats the case then im gonna have to go with the above statement and say that its highly probable that your starter is whats giving you the problem.
no thats what i dont get i had it in neutral i never leave it in gear. and every time i start my car i put the clutch in. just that one time i try it nothing happened now i cant even start it.
Double check your grounds.
Put your car to the on position, you should hear the fuel pump turn on. Goto your engine bay, connect the ground wire on the starter to the power on it. If it doesnt turn the motor or start the car the starter should be the root of the problems. |
Trader Rating: (53)
i would still check the starter if i was you. just the other day at work my buddy was driving to the store and his car was running perfectly fine. he shut it off and went inside. when he came back out his car wouldnt even attempt to turn over and it turned out to be a bad starter.
#16 | |
![]() Join Date: Nov 2006
Just find your starter, hit it with a long pipe, similiar to a jack stand handle, and you should be good.
...that is til it wont work anymore. which means buy a starter.
![]() Quote:
#17 |
I had the same problem recently with my clutch safety switch, though I was still able to push start my car to get it home. I ended up just replacing the switch so I wouldn't have to deal with the hassle of push starting everytime while I tried to diagnose. $2 part at autozone or wherever but it is a b!tch hanging upside down in the seat or twisting yourself to get to it to work on it.
#19 |
k i had my battery disconnected last night connected it just now tried to start it. found the starter tried hitting it nothing. next just take the damn starter to autozone. test it. and how do you bypass it.
yes im a noob but you gotta start somewhere its my first car trying to learn as much as i can i do google shit up i find it easier to talk to ppl that can dumb things down for me. im sorry that im annoying or some shit or if im putting up more than one forum up of the same thing i dont know how to use this website so if you gonna just get on here and talk shit about me why even bother clicking on the forum. thanks to everybody thats actually been helping out. |
#20 |
![]() Join Date: Nov 2007
I Say Push Start It Then If It Starts Trun It Off Then Try Starting It If It Dnt Start Then It Should B Ur Starter Sounds Like U Had The Sam Prob My Homie Did
#22 |
![]() Join Date: Oct 2002
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
You should google a few things before wasting bandwidth. First page on google. I'm sure there's more stuff out there to help you, but in the name of spoonfeeding. Here.
[ame]http://www.youtube.com/watch?v=d07mJQVrXZ0[/ame]
#23 | |
clutch safety switch06-30-2008 02:41 PMWhy Do You Capitalize Each Word Homie?whoes cars if i type like that y do u care Last edited by driftordiemike; 06-30-2008 at 04:12 PM.. Reason: add bad rep ??????????? |
#24 |
HAHAHAHA! That's funny. If it was me, you'd be a couple squares in the red by now. lol
#25 |
![]() Join Date: May 2008
thats whacked man i can start my car without the clutch depressed in and it still starts fine but i still push the clutch in everytime so i dont mess anything up
#26 |
just enough to get it rolling pretty good, but easist way is to push start is in reverse. works every time ive had to do it.
#27 |
k im just gonna get the starter checked out at autozone. anyways i got these lowering springs that the previous owner gave me and i was wondering if they would work on my stock suspension set up. my buddy said they looked iffy.
#28 |
![]() Join Date: May 2007
Hell yeah. Those coilovers are dope. Garunteeed to supa slam yo car and give you that hella tyte jdm look.
Pick up one of these also: ![]() Hella dope. Someone contact TOMMOTORSPORT. Dudes could do some serious business here on the forums.
1982 280zx Turbo Last edited by Dirty Habit; 07-01-2008 at 08:51 AM.. Reason: TOMMOTORSPORT BOOKMARKED!!!!!!!!!!! |
#30 | |
![]() Join Date: Mar 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
They meant to by-pass the safety switch, NOT the starter, you kinda need that. And to who ever was asking, hitting the started does work, I did it for about a month, then that stopped working and had to stop procrastinating and actually change it.
-Trevor |
