![]() Join Date: Aug 2009
SR20, S14 stuff for sale
Please READ!!!
S13 SR20 Intake Manifold - $45 -the manifold will come with everything shown, EXCEPT the iacv. I'll also be throwing in brand new intake manifold gaskets. S13 SR Flywheel - $40 S13 SR Exhaust Manifold - $50 -will come w/ 7-layer exhaust manifold gasket S13 SR Throttle Body - $30 -comes with throttle position sensor as well. Will come with brand new OEM throttle body gasket. S13 SR IACV x2 - $20 each -I don't know if either of these work and I'm unable to test them, therefore I'm selling these AS IS. Adjustable FPR (fuel pressure regulator) - $70 -I'm not sure on the brand, but I was told this is either a Nismo or Tomei type-b universal FPR S13 SR Ignitor Chip - $55 S13 SR20 Alternator w/ bracket and hardware - $90 S13 SR20DET/KA24DE ECU Water Temp Sensor - $20 -brand new, never used S14 KA/SR Dash Water Temp Sensor - $20 -brand new, never used S13 SR20 PCV Valve - $10 -brand new, never used S13 SR20 5 spd tranny - $200 -pulled from working setup. NO GEARS GRIND. Sensors, shifter, and clutch slave cylinder will be included. Tranny mount not included. There's a small leak in the rear where the driveshaft and tranny meet; the rubber seal/gasket needs to be replaced. This is a small fix. Local pickup/meetup only. S14 Rear Seats - $75 -pickup/meetup only S14 Nismo Power Brace - $100 -I want to note that the threads on one of the bolts is partially ground down (about 1/8 of the threads.) A new nut can still be threaded onto it without any problems and therefore this should have little to no effect on the bolt's holding capacity. This bolt is used to attach the power brace to the sway bar. If its that much of an issue for you, you could always just replace the bolt with a new one. Otherwise the brace is in great shape. S14 front sway bar - $35 -local pickup/meet up only S14 tension rods - $20 each S14 Zenki complete tail light set - $50 -no cracks, great condition. center piece does not come with reverse light bulbs. Last edited by CinSun; 05-30-2010 at 03:46 PM.. |
#11 | |
460
| 240sx, s13, s14, sr20, sr20det |
