ive searched but have only found it for the 91 240sx i have a 92 24sx se im trying to replace the fuel pump relay but i cant find it sorry for the nooby question ( im new to nissans) so if any one can tell me where its at thanks
Fuel Pump Relay Location
The fuel pump relay is a GREEN relay located in the fuse and relay box that sits directly behind the battery. Pull the cover and you should see 4 relays on the right hand side (looking at the fuse and relay box while standing in the front of the car). The 4 relays should be, from the back, the ECU relay (green), FUEL PUMP relay (green), headlamp retract relay (gray), and the condenser fan relay (blue). By the way, these relays should be identical between '91 and '92.
