iacv valve cleaning
i cleaned my iacv valve with break cleaner instead of carb cleaning is it a big deal? the iacv was off the car when cleaned so i should be good right and does anyone know the o ring size for the acc connecting to the iacv
whats that yellowish glue that looks like it holds rge end of the spring mines a bit scratched up I'm going to add some jb weld to it but I'm sure theres a bolt underneath that stuff and u know what size o ring goes between the acc solenoid and the iacv valve its self or is it a washer?
