how to hook up oil guages!
ok hooking up a mechanical oil presure gauge must be easy but no one knows how to hook up electronical ones.....there is one that runs straight oil to the gauge..but i have guages that are just wires...and know one knows how to hook them up..or its so hard that no ones wants to help me...i might sound stupid or what not but really how do you hook up electronical gauges!!!
![]() Join Date: May 2004
an electrical oil pressure gauge should come with a sending unit. But if it didn't find the place you got it from and they should have sending unit kits for that gauge.
![]() Join Date: Jan 2005
on DE KA you can installl it right under the oil pressure switch on oil filter housing. there is a "plug" bolt which you can take out with 5mm Hex key . only prolem you may have is finding a adaptor fitting to install the sending unit
#9 | ||
![]() Join Date: Apr 2003
i tried to use the lower hole to put my pressure gauge in. impossible. i couldn't fit a wrench in there AT ALL. alternator bracket and some other shit in the way.
switch location = no problem. |
![]() Join Date: Aug 2003
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
http://240sx.cubicdesign.com/article4.php
I have yet to install my megan racing oil pressure gauge which is still in the mail. Does any one know if they come with an aftermarket sending unit? Apparently from this Gauge Install the autometer oil press. gauge just comes with a fitting. How is it better to use an aftermarket oil sending unit rather than stock. |
what do you guys think of this technique that endyn uses.
http://www.theoldone.com/articles/oilpressure/ |
stock oil pressure sender on the SR and KA is just for the dummy light in the gauge cluster. The ECU doesnt take any readings from it...
What i did was just remove the stock oil pressure sender and install my Omori line there. Just leave the plug disconnected from the stock sender and the light wont stay on... My Omori gauge, and other decent electrical gauges come with a SS line with an adapter that is the same threading as the stock sender for the SR. You just hook the SS line, then mount the actual sending unit on the firewall, then you just get the wires from the sender to your gauge. Its strongly recommended that you dont run the sender directly on the block, as they can break from vibration and stress... contact the company who made the gauge and tell them you need the sender and whatever else it comes with it... |
