#121 |
![]() Join Date: Jan 2007
What he said haha. That's sick I hope someone figures out the speedo issue. Those clusters are pretty sexy. I've been looking for one of the euro 140mph s13 clusters for a while now.
![]() Boost Coming soon... |
#122 |
![]() Join Date: Sep 2008
now that i've had it for a year i might as well spill the beans....
If you cross reference the s2000 pinout(found on a lot of honda forums) and the 240 cluster pinout it really simple. -You can only use an ap1 cluster as the ap2 need the s2000 ecu to work -Power, ground, blinkers, brights, dimmer just use the same wire on the 240 cluster harness -fuel gauge uses the same wire but requires a 27?ohm resistor to be somewhat close -tach is the wrong voltage so you either need a dakota converter or do whats called a "pull up resistor". T into the rpm signal a 12v source with a 680?ohm resister. This will bring the 5v 240 signal upto the needed 12v signal. Will be accurate for 4 cylinder engines. Think that covers the basics. It was a year ago i did the swap with a digital cluster harness so i dont have it written down anywhere. |
#123 |
Just got this done on my convertible today. Bought cluster w/HUD on Craigslist for $110, they pulled it off a junk yard thinking it was a plug and play or something.
HUD heads up display works(Do not cut the dashboard, get a S13 coupe dashboard with HUD slot) Mad wires to match up, nothing a FSM and a solder iron can't handle Download a '94 maxima, 89-94 240sx FSM and prolly some pills and you're good to go! Just match up the wires Fuel gauge is not working properly, might need a maxima fuel sending unit. Shows 3/4 of thank but I only have 1/4 in tank with the original cluster. Need help on this...
Last edited by bombaybe; 06-04-2013 at 11:08 PM.. Reason: Adding more information |
#124 |
Thats awesome ^^^ actually the first time I've seen one actually wired in and running in an s-chassis. Thanks username. Seems like it would have to be done the old fashioned way.
#128 |
This may be getting a little extreme, but I supposed with patience anything is possible. I think this would be very nice looking. If you've ever sat inside a CRZ, you'll know the pictures do this cluster no justice. And correct me if im wrong, but I believe as you approach redline/enter redline, the backlight to the tach fades and eventually turns red. Mega awesome in my opinion.
http://0.tqn.com/d/cars/1/0/L/7/2/11_crz_ip.jpg http://www.ridelust.com/wp-content/u...s1-500x333.jpg |
#132 |
any idea? no rpm. ca18det cluster incl resistor and sr20det with 62ecu.
triplechecked pinouts. https://www.youtube.com/watch?v=ACoQvaZO89s |
#133 |
Instagram: @hexagarage for VQ S Chassis Parts |
#135 |
Thanks! The filter makes it appear that way but it's OEM. The stock S13 dimmer control switch and headlight dim will be wired in soon.
#137 | |
![]() Join Date: Jan 2014
#140 |
![]() Join Date: Oct 2013
Finished up my cluster last week. Made the backing plate out of a butting board. I'm a cheap fuck, but what broadfield does is amazing. nothing but respect for him. Thanks for getting me my gauges Toby.
#143 |
anyone ever messed with a German s14 cluster? the one i got said its a zenki unit and it should just work like all the rest of the cluster. but my tach is off pretty bad. its just a stock zenki with a KA
#145 |
