Old 10-17-2011, 05:53 PM   #1
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
Dohc to sohc sr chassis swap! Questions??
Hey guys, long story short I'll get straight to the point. I picked up another shell, sohc straight body, no rust, good paint. Vin number said DOHC, dash vin and firewall vin match. BUT the engine in the car was a SOHC, and the F4 plug in the dash is for a SOHC.
Now I swapped throttle cables with my old Dohc chassis, along with suspension, 5lug, brakes, gauges, ext. My wiring harness is from Yuri, from like 2005. No problems with it at all! My problem is the plug from the ecu that is suppose to plug into the F4 plug of course doesn't plug in since it's a white sohc plug and not a brown Dohc one.
With that said, what happens if I don't plug that in? What do I need to do in order for my fuel speedometer to work, and what would I need to do in order to get that plug to plug in !!? I know repin, but how I know the speedometer wouldn't work if I repin it with a Dohc plug!? I have no clue as to how to wire it up since I'm horrible with wiring. Hence why I have a wiring specialties wiring harness so I'm ny chasing gremlins in wires!
Someone! Some awesome Guru help me out! Tell me what to do! Because this is ALL I have left to do!
SLiDe_WaYz is offline   Reply With Quote
Old 10-17-2011, 07:48 PM   #2
s13silvia123
s13silvia123's Avatar
thats the dash plug swap with the brown plug, its color coded so it will be simple do it right though
Old 10-17-2011, 07:57 PM   #3
SLiDe_WaYz
SLiDe_WaYz's Avatar
It's color coded do I basically cut one wire, and solder the same wire with the same color wire on the brown plug?
Old 10-17-2011, 08:20 PM   #4
DS562
DS562's Avatar
DS562 is an unknown quantity at this point
here you are, good sir.
Yellow/Red –Tach
Yellow/Green–Speedometor
Orange–Ignition start
Black—Ground
Blue/Black—Water temp sensor
There will be some wires left over. These are for the SOHC’s diagnostic plug, and are unnecessary. Please note: Your car will NOT be able to hook up to a CONSULT tool.
2) Use a soldering iron to splice the wires together. It makes for a much cleaner job, and a cleaner electrical signal.
3) You need to swap out your tach if you want one that works. No wiring is involved, but it must be done. Simply pull your gauge cluster and remove the three screws behind the tach. Lift and separate. Replace.
source: KA24e to KA24de swap – Step-by-step
Zeeeeeeeee32
DS562 is offline   Reply With Quote
Old 10-17-2011, 08:28 PM   #5
SLiDe_WaYz
SLiDe_WaYz's Avatar
LEGIT! I searched guess I didn't search hard enough. Thanks man!
Could I just put in a Dohc cluster and it work?
Old 10-17-2011, 08:30 PM   #6
DS562
DS562's Avatar
yeah, the reason for the splicing is that the SOHC tach got signal from a different pin or something like that.
Zeeeeeeeee32
Old 10-18-2011, 06:43 AM   #7
airman
airman's Avatar
airman is an unknown quantity at this point
SOHC tach won't work with the DOHC at all.
2014 Absurdity Build
RIP S13 KA-T HX35 419whp
airman is offline   Reply With Quote
Old 10-18-2011, 10:19 AM   #8
SLiDe_WaYz
SLiDe_WaYz's Avatar
So I basically just repin those wires and swap tach's from the sohc cluster to a Dohc one?
If I'm not mistaken, doesn't one of those wires work as the fuel pump? To prime the fuel pump when the ignition is turned on?
Old 10-18-2011, 11:05 AM   #9
Sileighty_85
Sileighty_85's Avatar
SR20DET Swap Engine Harness Wiring Diagram Guide SR SR20
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-18-2011, 05:57 PM   #10
SLiDe_WaYz
SLiDe_WaYz's Avatar
Originally Posted by Sileighty_85 View Post
That's simple, I was thinking I had to re pin all the damn wires
Old 10-18-2011, 10:48 PM   #11
DS562
DS562's Avatar
wtf i couldve swore it said sohc TO dohc. i swear, im becoming dyslexic. my B.
Zeeeeeeeee32
