My
passenger window wont work, i have a 95 s14 zenki and for some damn reason my passenger window doesnt work not from the main switch not from any switch the FSM says to repair harness but i dont think anything is wrong with the harness im thinking some kind of relay but i cant find any besides the power amp and i hear thats only for the auto down function. i dont think its any fuses because its only my passenger windw that doesnt work everything else is good any suggestions would be great if you can tell me where to locate the relays that would be AMAZING. |
My driver side swith went out yesterday... I tried switching out the whole white box and it still didnt work, but the passenger switch and lock switch still works
I think we have the same problem, except mine is with the driver side. My passenger side window will go down but not driver side |
![]() Join Date: Dec 2002
The motor is likely dead. There is no relay for the passenger side window.
There's literally hundreds of threads on power window diagnostic and repair. You're not the first to have a problem, research it a little instead of making a new thread next time.
The window amp is the white box you mentioned, only found on '95 models. If you swapped it out and still have nothing, the motor is dead. Common sense.
i guess i can try the amp next but im not sure how that helps my passenger window and i did research more than i would like to admit the motor is not dead because i wired a new one up and it didnt help so i must be missing something thanks for the help but i really dont think its the amp box because my driver side window is still in buisness
