D-turbo-lads Irish 180sx build KOUKI
hi all dont really post very often on here but really like the site being comming and goin the last 2 years looking for info and help to hlp me along with my build ....
so any way own my 180sx since may 2011 and have it since love the car its my daily even tho only does 10km a day hah. so here ther spec of the car at the moment will add all my pics as i go along with it . over 200 (il narrow it down ) EXTERIOR red full kouki kit Front bumper splitter and end cap Side skirt Rear bumper spats and center piece Kouki spoiler (to be fitted. magic areo roof spoiler raybrig headlights lazy eye thingy crystal side repeat's SUSPENSIONS BRAKE'S AND WHEELS crystal bumper lights race gear rear coil overs with pillow ball topmounts unknown front make coilovers with pillowballs and camber plates subframe locking collars tein front tension rods cusco rear toe arms cusco rear camber arms unknown make rear traction arms 5 stud conversion brand new balljoints brand new s14 inner tie rod's brand new s14 trackrod ends poly bush's in lower control arms s14 4 piston front brake's driftworks braided lines all round soild steering bushing 20mm front spacer's fancy stud's front strut brace rear cusco brace work emotion cr kai's front 17x9 et30 215/40/17 uniroyal rain sports ( et 10 with spacer) rear 18x9.5 et30 225/40/18 sunnys ( et 20 with spacer ) INTERIOR apexi rsm apexi pencil turbo timer nardi 350mm 50mm concave balck red stitch 2 60mm gauges water temp and volts hand brake grip fly off button defi black face 60mm boost gauge and controller . red recaro driver seat apexi safc japspeed short shifter up rated fusion speaker's jvc cd player ENGINE AND DRIVETRAIN sr20de +t conversion .. braided turbo lines t28 s15 bb tturbo front mount cooler and pipes japspeed 4brancj plated mani 3" elbow unknow make all A/C removed including rad pump and lines s15 50mm alloy rad dw oil cap blitz 7mm leads all multi layer gaskets all brass non seize nuts s14 vvt injector's turbo flywheel exeedy stage 1 clutch (soon to upgrade ) 2 way diff (unknow'n ) raito approx 3.9 ish diff oil castrol b373 box oil 75w/90 the day i bought the car . silly wheels and uras everywhere the shell/body was very clean small spec so had'nt been fuked with only upgrades when i got it was carbon bonnet cusco toe arms 2way diff 4 branch manifold 3" exhaust so i had few small issues with my fiberglass and passenger wing in the first cuppla days ![]() so went out and bought so coilovers some castrol b373 diff oil and also done a full fluid change on the car ... ![]() bought my 1st set of wheels first or may auctually will add pics and specs of all my wheels ive had as i go along. thanks for looking ![]() |
