Hello Zilvia,
I have an odd issue after doing a V8 swap in my '96 S14. My, what seems to be bi-level door motor, seems to be stuck going back and forth as long as the key is in ON position or the car is running. With that said, it does not affect anything to my knowledge. Every button on my climate control works like it's suppose to. Perhaps I am focusing the wrong thing? I am looking at the FSM and this seems to be it, but there isn't a lot explaining what it does and how it does it. If you have experience this issue or have experience replacing this part, please let me know. Thank you. |
I would check the wiring at the dash plug...not sure what would make that actuator go crazy like that , but there is a wire for the a/c recirc relay down there. I dont remember how it affects the blend doors when triggered but maybe worth looking into.
Is it actually moving back and forth, or getting to a position and then just sitting there "clicking"?
Basically the bi-level door is closed in every HVAC position except for face/feet. I unplugged mine until I was able to get a replacement motor. Pulled the bad motor apart and noticed that a few of the plastic teeth on the gears had stripped, causing the clicking noise I was hearing. If your motor is cycling between full open and full closed, then there's something wrong with your HVAC controller. |
#5 | ||||
Thank you for the responses!
-The motor buzzes then clicks, buzzes then clicks... over an over again non stop. -That does not seem to affect anything at all as far the the controls go. All of the buttons, fan speeds, and heat/cold lever work as they should. (except for A/C of course because I have yet to make custom lines) -Here is a video (turn up the volume) Quote:
How hard was it to replace? It seems like I will have to pull the headunit to get a better access. |
#6 | |
In the video you linked, the arm isn't moving at all, my guess is the teeth are all stripped inside. You can unplug it and it will be fine. That door only opens with bi-level setting, it's closed for every other setting. I think it balances the ratio of head/legs, because even unplugged air still came out the top and bottom for me. |
| 240sx, bi-level, door, motor, s14 |
