![]() Join Date: Apr 2007
accord rear lip for s14 rear bumper, chrome inside door pulls for s14
I have 1 accord rear 3pc lips that fit the s14 for sale. 50 bucks shipped per set.
2 sets of the chrome interior door handles/lock combos. 25 shipped per set. Please pm for pics. Prices are firm. Last edited by new2sr20; 03-16-2013 at 09:20 AM.. Reason: 3 sold |
![]() Join Date: Feb 2012
That is surprisingly good fitment. Did you have to modify it? Do the mounting holes line up or would we have to make new ones? Which is no problem, I'm just clarifying
Drill new holes and u have to modify the door handles
for the lip, you will have to drill the bottom of the rear bumper to mount it.
not sure for the door handles, 97nismo is correct, I have not done them my self yet, but I hear they have to be dremmeled to fit perfectly |
pics of lips as promised, they have all been cleaned and painted with high temp flat black. 1 of them has a little sag of paint on it...not really sweating it, just did it so you guys have something nice to look at when you open the box. chrome door handles. |
I have already put the lip on, I will be taking it off for the write up, the trimming of the lip is REALLY simple. Putting it on is a breeze, I used the oem clips, and you will need 6 screws as well for the sides. I recommend starting with the passenger side piece as it requires no trimming. then the center which you just cut on the far left side by the exhaust after the 4th clip from the right, then the left piece has to be cut by the exhaust as well. really easy install. You will need a small cut off tool, I used a dremel which worked perfect.
