Ok i have the arp headstuds and have the torque
specs for s14 sr20det but what is the number sequence to torque them. example front to back 1 9 2 10 3 7 4 8 5 6, or middle starting 5 6 4 8 7 3 10 2 1 9 or 6 5 8 4 3 7 2 10 9 1 that was a example i need the right number sequence and where can i find. just one arp head stud, i bent one dont ask how (i feel embarassed) any info is great thanks |
Dude, you really need to get your hands on an FSM...
But to hand feed you, Front of cylinder head is at the 7/8 end. Start in the middle and work your way out following that order below... 7 3 1 5 9 8 4 2 6 10
My SR20VET |
![]() Join Date: Dec 2004
Trader Rating: (58)
with that said, also do them in increments of 15 ft lbs to to 75, then 10 more to 85 Use ARP or Moly lube on them.
...you do have an FSM I hope...
#6 | |
![]() Join Date: Dec 2003
Always tighten from the inside out and loosen from the outside in. It's the same sequence for everything in the head.
Trader Rating: (58)
![]() ![]() I'm curious as to that as well!
ARP says to tighten in 3 increments to 80ft/lbs. I do 27,54 then 80.
The thing is, it’s a gearbox, okay? It has one job to do! One job! Pull the lever… ‘Am I a pencil? Am I a cauliflower? Am I a nuclear power sta– I’m a gearbox! Oh, heavens, I’m gonna swap some cogs around!’ Jeremy Clarkson on Automatics |
![]() Join Date: Aug 2005
My FSM states to get the fronts down first, then proceed in the middle->out fashion. So it goes 9-10-1-2-3-4-5-6-7-8
This is my clever and witty signature. |
^that's what it says above. I'm just confirming the sequences for head components. Tighten from the inside out and loosen from the outside in.
#12 | |
Trader Rating: (58)
I always just did them in my sequence up to 85...unsure why, probably from some oldschool forum 'folklore' (hi Def!) when I first got into these forever ago.
^ damn, we're getting old...
