![]() Join Date: Jul 2005
help me finish my fuel system because I am newb
Hello fellow zilvians,
I need some experienced advice. The last thing on my list for the new car is fuel system. I've never seen or used "posh loc" style hose before and I need to know more about how to use it correctly. 1. I want to know if I can use this hose http://www.ebay.com/itm/3-8-Syntheti...ZXjsy5&vxp=mtr and clamp it directly onto the factory feed and return lines, and if not, how to go about doing that. 2. Next, I want to know if this barb fitting http://www.ebay.com/itm/BLUE-3-8-bar...FUwSi3&vxp=mtr which just says "barb" can be used somehow, and if the push loc line wont clamp to the factory feed/return, then I can use basic rubber fuel hose with these barb fittings in an aeromotive regulator to fuel the engine. And finally , I want to use this regulator http://www.ebay.com/itm/Aeromotive-1...torefresh=true With some 6-an fittings, either push loc, or basic barb, unless you experienced have another regulator in mind (I've never bought a regulator before, always used OEM stuff). This is for LSx application 600~bhp. |
Good advice, what do you think of it here
http://www.ebay.com/itm/401228408594 Many sold good feedback, usually ok I bought some barb fittings for the time being, and I bought a couple feet of pushloc hose to play with. The barbs will help me fuel the engine with regular rubber hose for now; when I figure out how the pushloc stuff works I will switch over to it. I've never had to setup an aftermarket regulator, well, almost. One time about 13 years ago I setup an aftermarket regulator on an EFI V8 setup in my backyard. I used braided hose though. I wanted to avoid hose ends because the real deal are very expensive, and I dont trust the chinese hose ends with fuel. Seller responded: "yes sir, we are 100% direct warehouse for Aeromotive. I'd just call them up www.aeromotive.com and verify with them. " |
#4 | |
![]() Join Date: Jan 2010
