Old 02-01-2008, 10:29 PM   #691
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
Originally Posted by koukimatt View Post
I just got a set of Gullflames, same fitment (18x9.5 +15). No tires yet, sorry... still trying to figure out what size I need. Here's what they look like on the front of my S14. Stock fenders, no roll or pull so far. The car is obviously off the ground... this is just to show how far out the wheels go.
If I get tires with stretched sidewalls, I can probably get away with no spacers up front. With vertical/flush or slightly larger (bulged) sidewalls I'd get 5-10mm spacers to make sure the tires clear the coilovers.
I'm not slamming the car, and I don't plan on drifting it... much. Any suggestions on tire size?
235/40 should work fine if you're no gonna go that low. FYI, I run 18x9.5 + 7 (+12 w/ 5mm spacer just cuz i think it looks better. lol) with a 225/40 on the front of my S14 all day every day. works great.
Sorry i dont have a more recent picture of my car and one with a better angle on the front tires, but you can kinda see that the stretch isnt that crazy.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
Old 02-01-2008, 11:52 PM   #692
SlideAlliance
SlideAlliance's Avatar
SlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond repute
SL500, 20's, staggered, tire tuck, decent fitment but nothing superflush like the FC
Battle Idol Works 2015
SlideAlliance is offline   Reply With Quote
Old 02-02-2008, 12:48 AM   #693
hitman
hitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfection
Send a message via AIM to hitman
maybe new pics soon if i can get my hands on a camera
driftparty.com
hitman is offline   Reply With Quote
Old 02-02-2008, 12:49 AM   #694
hitman
btw i cut my rear overfenders up 1/2 an inch because they get weird at the bottom
driftparty.com
Old 02-02-2008, 01:01 AM   #695
Full-Lock
Full-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfection
Send a message via AIM to Full-Lock
@revat
are your fenders pulled at all?
Full-Lock is offline   Reply With Quote
Old 02-02-2008, 02:11 AM   #696
revat619
Retired General
revat619's Avatar
Originally Posted by Full-Lock View Post
@revat
the rears are. fronts are just rolled.
www.Jspec.com
Old 02-02-2008, 02:57 AM   #697
Blackparade
Blackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfection
haha! nice rear end shot!
Blackparade is offline   Reply With Quote
Old 02-02-2008, 06:21 AM   #698
yokotas13
yokotas13's Avatar
ride height ftw
18x10 -30
225/40
yokotas13 is offline   Reply With Quote
Old 02-02-2008, 07:01 AM   #699
DOOK
DOOK's Avatar
DOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfection
Originally Posted by revat619 View Post
don't think i've ever seen your car before, it looks great brotha.
<------ Grumpy Old Asshole
MY REVIEW THREAD: Ltdnismoracer4=DOOK
#/f/showthread.p...ltdnismoracer4
DOOK is offline   Reply With Quote
Old 02-02-2008, 02:00 PM   #700
koukimatt
koukimatt is on the path to ruinkoukimatt is on the path to ruin
Originally Posted by Risu2112 View Post
My thumb at the first joint isn't even 20mm(my pinky being around half that), you might want to go back and remeasure that gap.. looks way too close even with rock hard suspension to not rub, spacers imo. :P
Yeah, my finger isn't quite that big either.. I was just guessing at the gap since my finger fits between the rim and the coilover, and my knuckle is a little bigger than 1/2".
I knew I was probably going to need spacers, but I wasn't sure just how thick they needed to be... 5mm, 10mm? The wheel looks okay from the front and I don't really want it projecting way out past the fender if possible.
My bro and I were a little suprised at how far the wheel sticks out even without a spacer, since we've both seen 18x9.5s with +12/+15 offsets up front on an S14 before and we didn't remember them looking so wide. Maybe the hats on my brake rotors (Brembo Z32 replacements) are thicker than normal, or (more likely) they had wider fenders. Guys with 18x9.5s up front: do you have fender rolls/pulls or overfenders? How much wider are they than stock?
koukimatt is offline   Reply With Quote
Old 02-02-2008, 04:18 PM   #701
revat619
Retired General
revat619's Avatar
my fenders are just rolled up front and im at 18x9.5 + 7 (+12 w/5mm spacer)
You dont need wide fenders unless you want to run something bigger than a 235/40 and you still want to be really low.
DOOK, thanks man.
www.Jspec.com
Old 02-02-2008, 07:33 PM   #702
1cleanS13
1cleanS13's Avatar
1cleanS13 has a brilliant future1cleanS13 has a brilliant future1cleanS13 has a brilliant future1cleanS13 has a brilliant future1cleanS13 has a brilliant future1cleanS13 has a brilliant future1cleanS13 has a brilliant future1cleanS13 has a brilliant future1cleanS13 has a brilliant future1cleanS13 has a brilliant future1cleanS13 has a brilliant future
Couple new pics I took today...
18x9.5 +12 with 225.35.18
18x10.5 +15 with 235.40.18
1cleanS13 is offline   Reply With Quote
Old 02-02-2008, 08:02 PM   #703
smellslikecurry
smellslikecurry's Avatar
Trader Rating: (33)
smellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfection
Feedback Score: 33 reviews
looks awesome...you should lower the front a tiny bit more
smellslikecurry is offline   Reply With Quote
Old 02-02-2008, 11:09 PM   #704
ramman434
ramman434's Avatar
ramman434 will become famous soon enoughramman434 will become famous soon enoughramman434 will become famous soon enough
Revat, what are your wheel and tire sizes exactly? I'm hoping to get some LMGT4's for my Kouki this summer and have been trying to figure out a good wheel fitment, so that would help me out alot. I have stock suspension right now, but hopefully that will soon be fixed.
ramman434 is offline   Reply With Quote
Old 02-03-2008, 12:14 AM   #705
raging panda
raging panda is an unknown quantity at this point
Send a message via Yahoo to raging panda
Reading rocks
www.panicmodedrift.com
raging panda is offline   Reply With Quote
Old 02-03-2008, 12:21 AM   #706
revat619
Retired General
revat619's Avatar
the fronts are 18x9.5 + 7 ( + 12 w/5mm spacer) 225/40/18
the rears are 18x10.5 + 10 (+ 15 w/5mm spacer) 255/35/18
however, in that old pic, my rear tires were 245/40/18
www.Jspec.com
Old 02-03-2008, 05:11 AM   #707
yokotas13
yokotas13's Avatar
Old 02-03-2008, 09:27 AM   #708
95KA-Turbo
95KA-Turbo's Avatar
I guess the wheel services are paying off man, your car doesn't even look remotely close to how it was when I saw it in September! It looks awesome man.
Old 02-03-2008, 06:28 PM   #709
wanganwonder
wanganwonder's Avatar
wanganwonder is a splendid one to beholdwanganwonder is a splendid one to beholdwanganwonder is a splendid one to beholdwanganwonder is a splendid one to beholdwanganwonder is a splendid one to beholdwanganwonder is a splendid one to beholdwanganwonder is a splendid one to beholdwanganwonder is a splendid one to beholdwanganwonder is a splendid one to beholdwanganwonder is a splendid one to beholdwanganwonder is a splendid one to behold
better photos someday when my lens isn't bussup
F: 18x10 -17 225/40 ss595
R: 18x12 -17 245/40 ss595
wanganwonder is offline   Reply With Quote
Old 02-04-2008, 04:26 PM   #710
ramman434
ramman434's Avatar
Reading rocks
Thanks douchebag, reading does rock. If you had thoroughly read you would have realized he only listed his front sizes. That's why I was wanting to know his exact sizes for all 4 wheels, not 2. Congrats...
As for Revat, thanks. I wasn't aware that they came in a 10.5, I thought it stopped at 10. Good, that looks about the exact sizes that I'm wanting to use on mine. I plan on powder-coating them black however. I've got to start shopping around for a good powder-coater in the Nashville area that doesn't charge outrageously...
Old 02-04-2008, 04:47 PM   #711
sultan
sultan's Avatar
sultan will become famous soon enoughsultan will become famous soon enoughsultan will become famous soon enoughsultan will become famous soon enoughsultan will become famous soon enough
18x9 +0 225/35 18x10 -13 245/35
no adjustable suspension arms at all, gay single height adjustable coils with over 2" of droop in the rear. not to sure about drooping up front, only way to go lower though
stock uppers too, no camber plates on this pos
sultan is offline   Reply With Quote
Old 02-04-2008, 05:04 PM   #712
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
lol those wire wheels are sweet
HS13KLS is offline   Reply With Quote
Old 02-04-2008, 06:13 PM   #713
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
17x9 +17 235/45..
needs to be loweredddd alot more.
possibly spacer + roll/pull.
needs alignment/camber.
My iTrader rating!
babowc is offline   Reply With Quote
Old 02-04-2008, 07:37 PM   #714
Topless_92
Topless_92 will become famous soon enoughTopless_92 will become famous soon enoughTopless_92 will become famous soon enough
Those wheels are baller Sultan haha
Topless_92 is offline   Reply With Quote
Old 02-04-2008, 07:37 PM   #715
tattoo131313
tattoo131313's Avatar
tattoo131313 is close to perfectiontattoo131313 is close to perfectiontattoo131313 is close to perfectiontattoo131313 is close to perfectiontattoo131313 is close to perfectiontattoo131313 is close to perfectiontattoo131313 is close to perfectiontattoo131313 is close to perfectiontattoo131313 is close to perfectiontattoo131313 is close to perfectiontattoo131313 is close to perfection
WTF? those Emitz kick ass.Good offsets too
tattoo131313 is offline   Reply With Quote
Old 02-04-2008, 07:44 PM   #716
quentinchan
quentinchan is making his/her stupidity well-knownquentinchan is making his/her stupidity well-knownquentinchan is making his/her stupidity well-knownquentinchan is making his/her stupidity well-known
Sultan your wheels are hot! you wanna sell it?
quentinchan is offline   Reply With Quote
Old 02-04-2008, 11:39 PM   #717
yokotas13
yokotas13's Avatar
lol
hey sultan, are theose the emitz you got from me?
i should haev kept them
Old 02-05-2008, 07:32 AM   #718
axiomatik
axiomatik's Avatar
*snip*
where are your brakes? Is that part of the wheel design?
Old 02-05-2008, 01:39 PM   #719
270 R
270 R is an unknown quantity at this point
Looks like it sits alright (from what little i can see)
I could be wrong here, but i think your best bet on tire size would be a 235/40/18.
Make sure you post some pics once you've got them on.
I just ordered mine last week so i'll take some too once they're in and on.
270 R is offline   Reply With Quote
Old 02-05-2008, 02:29 PM   #720
drifterRS
drifterRS's Avatar
drifterRS is on a distinguished road
i know this is really retarded for me to ask but does anybody have pics of a s13 fb with sportmax 504 on it? flame as u must but i just want to see them
drifterRS is offline   Reply With Quote
