95 tranny in 96, OBD problem.
I have a 95 manual transmission in 96 with 96 manual ECU and it is throwing me a CEL light.
I only hooked up speed sensor so I do not know if the light is caused by other stuff or lack of OBD II stuff. Has anyone used OBD I transmission in a OBD II car? Is there anything I can do to trick the computer? 95 ECU maybe? I live in VA and I just need to pass the emission. Thanks. |
![]() Join Date: Dec 2002
Transmission and wiring is identical for all S14s. Plug in the CPS and neutral switches, they're both required to keep the CEL off, has nothing to with OBD-II.
#4 | |
hey sounds kinda newb but..i just did my swap on a 98, and i'm kinda having trouble finding the crank sensor plug in from the top of the tranny, could you guys help me out, having trouble finding the plug in, don't remember unplugging it, any pics or details would help greatly
It's part of the lower harness, 3pin plug, pink, blue, and gray IIRC.
#11 | |
#13 | |
