F/S- 1992 Toyota Aristo
Want to build another rx7, so this car has to go. Mostly testing the waters for now. Its a January 1992 build year so legal stateside now. It's pretty solid for a 25 year old car, just needs a coat of paint and some repairs to the aero.
Car was tuned/Dynoed this summer. Made 500whp at 1 bar before running out of turbo. Change the turbo, make more power. HKS 272 cams K1 Rods CP Pistons Titan Timing Belt tensioner Titan Timing gears Gates Racing Kevlar Timing belt Ported Oil Pump MR-S Shimless Lifter Buckets Supertech Dual valve springs Custom Intake Manifold 80mm Throttle Body AEM 3.5bar Map sensor Custom Twin Scroll Exhaust manifold Comp 67mm Turbo Twin Tial MVS Wastegates Tial Bov Sard Fuel Rail 1000cc Injectors OEM Gaskets 4” front mount AEM water/meth with custom reservoir AEM 320lph fuel pump AP engineering Powerfc and Commander Aeromotive FPR Fuel Lab 82802-1 Fuel Filter -06 Return -08 Feed TRUST Oil filter relocation/thermostat -10 Oil Lines to relocation and oil cooler Setrab P/S Cooler R154 swap JZZ30 Ebrake OS Giken TS2BD(freshly rebuilt this spring) OS movement alteration kit Driftmotion Billet Shift forks Marlin Crawler Thrust washer New bearings New Synchros One piece driveshaft Diff/Driveshaft Rubber Isolater delete LS400 Front brakes with Stoptech Slotted rotors Wilwood Pedal Box Firewall mounted New front upper control arms New lower ball joints Replaced front tension arm bushings with polyurethane Rear suspension bushings swapped to polyurethane PBM Coilovers Factory Torsen Diff (can include open diff axle stubs if you plan to install aftermarket lsd) Aluminum diff mounts Aluminum Subframe mounts Aluminum motor mounts Solid Tranny mount Battery Relocation AEM UEGO Defi Racer Oil pressure Gauge Apexi Water Temp Gauge Greddy Exhaust Temp Gauge Greddy Boost Gauge Sparco Pro2000 Drivers Seat Recaro Passenger seat Rays Revolvers 18x9 +24 front 18x10 +24 rear Dunlop Direzza Z1 Star Specs front and rear Kazz Sport Aero What it needs; Better driveshaft Body/paint Bigger Turbo Needs Stereo Legal stateside January 2017 Looking to get around $18500usd Delivered within reason (thinking any state west of Texas) if you want to deal with arranging everything yourself then make an offer. Would also be interested in partial trades for clean/titled FC3S rollers, preferably with no sunroof. Car is located near Calgary, Alberta. http://imgur.com/a/5IRVw Hood's popped, more pictures in album. ![]() Last edited by C*bass; 01-13-2017 at 08:56 PM.. |
Thanks, your r32 isn't too bad either.
I should also add I have a pile of spare parts to go with it (axles, rack, a/c, coilovers) Would also consider trades for sv1000, rc51 or maybe a vstrom. |
