Help!!!!
So I did a little pool on my 1995 s14 that is stock. An after it started miss firing cylinder four . When I gass it sounds like it's not getting enough fuel or bugging . Did a compression test everything is good on all cylinders. Spark plugs are good so are wires ... If any one has had this problem pleas help!!
Sent from my iPhone using Tapatalk Last edited by flores.rudy22; 11-07-2015 at 05:03 PM.. |
Www.PowerAutosports.com |
![]() Join Date: Dec 2009
#/f/showthread.php?t=297481&page=627
wrong section bud. Post this question in the small question's thread^^^ p.s. did you check the injectors?
is it a in ground pool ? who's this miss firing she sounds hot !!! also who's bugging ? in the photo you have did you spit or swallow or you still haven't made up your mind ?
