Fuel Hardlines
I'm having trouble finding exactly what mates to these 3 hardlines .. I know the middle is for the fuel filter. Which is the return side, and what does the other do?? Searched, Googled, and everything else.. Need some help thanks.. Cars a 97 kouki 5spd w/ RB25..
Forgot to put pic... The 3rd line is sorta cut off the shot (shit shot I know, but you get the idea)
Yeah I used this pic to find out what the clutch damper was at the time ...
![]() Join Date: Nov 2013
I see, well props on that car man. That's like a dream car for me.
'91 s13 (Drift Rocket Under Construction) 2000 civic Si Coupe (Daily) |
Thanks.. No idea what the lines are ??^^^??
Nope, just giving you bumps and props. Have you tried hitting up a r33 forum?
Sent from my SCH-I535 using Tapatalk
Yeah everything, I could personally think of .. This is S-Chassis related tho
Ah, I see. Haven't touch the fuel lines yet on my 13. I'm sure there HAS to be a diagram somewhere on the internet.
Time to consult Google, brb. Sent from my SCH-I535 using Tapatalk
http://www.tune2win.com/index.php/di..._g35_coupe_qua
Check this out and let me know if it helps. The fuel picture is about half way down Sent from my SCH-I535 using Tapatalk
You have fuel feed, return and perhaps a vent line from the fuel tank to the charcoal canister. The FSM will help you figure out what ones are what. Fuel feed should go to your fuel filter and then to the feed on the rail.
My SR20VET |
