![]() Join Date: Jan 2008
Location: You can tell how I walk, I ain't from around herr..Five6Duece, Kings Only
KA24DE in pieces-complete motor
I have a complete KA24DE that is in pieces, taken down to the block. I was going to rebuild it but then i noticed the cylinder walls were recently honed, you can still see the swirl makes perfectly. then i got lazy and turbo'd my sohc instead.
I have eveything, let me know what you want/need with a resonable offer, it will not be turned down. I work in santa ana but live in long beach, pick up ONLY |
its taken apart so its not technically a long block....you can have all the long block essentials for $150 which would consist of
short block oil pan front cover/oil pump cylinder head w/cams-cam gears, timing chain and retainers. freshly powder coated valve cover-metallic blue. and everything else i can give you minus intake/exhaust and drive accesories |
Replied to your pm
have lots interested. It's first come first sold. Clutch,flywheel,pressure plate and valve cover pending short block, cylinder head, long block basically also pending. I'm not holding anything, you want it, come get it! |
im gonna hold and see what nismo tuner and i10cruiser figure out, if they dont come thru by saturday first to pick up head can have it, $50 is fine.
