![]() Join Date: Jan 2009
Another s13 Build Thread
I don't post very much, but I'm bored at work so I decided to chronicle my car's progress. Most of it is copy/pasted from various other forums I'm on, but I don't have an actual "build" thread. I've owned an s13 for almost 5 years now, and I think it's at a point where I consider it done.
I originally bought my 91 hatch for $300 off craigslist, guy I bought it from had drifted it into a curb and bent a bunch of front suspension stuff. While fixing it I upgraded to coilovers and bought some wheels, Tanabe Sustec Pros and 16x8 +10 Rota RB-R. It was also auto, so the first thing I did after fixing the front end was perform a 5sp swap. Here is a picture of it at that stage: ![]() I wanted to drift it, so I looked around for local drift events. The closest one was Driftwater, it's hosted by LookoutDrift/US Drift. I tried to go ka-t but that plan failed, so I was back to stock KA for the event, however I was still running my tuned ecu. I learned a lot at that event, here's a picture. ![]() After my first few events I wanted to try ka-t again. This time I did it better, but I still cut a lot of corners. After figuring out an ignition issue I was running 7 psi on a t25, I thought it was the fastest thing ever. I think this picture is of that setup. ![]() After the ebay turbo blew I decided to upgrade to a GTi-R t28. Here are some pictures from that: ![]() ![]() ![]() Unfortunately I wanted to break 300whp with 370cc injectors and stock mafs. I got close at 12 psi, but I blew my ringlands in the process. I still drove it around for a while at lower boost, smoked a lot but still made decent power. ![]() I got a friend to take some rolling shots, the car was pretty haggard in this stage but I thought it looked cool. ![]() ![]() ![]() ![]() Around that time I swapped in another KA, I was tired of burning oil due to the ringland issue. I think it's also around that time that I swapped everything over to a cleaner shell, not sure though. Either way the new shell was the same color, you couldn't tell it was a new car. This is either during the engine swap or the shell swap: ![]() I got some new coilovers because the Tanabes didn't go low enough. I also got to drift VIR's Patriot Course, that was a blast. Pictures: ![]() ![]() My oil pressure had issues. By issues, I mean I had almost none. I decided to tear apart the blown ringland block and build it, but I ended up saying screw it and rebuilt my turbo instead. ![]() Around that time I decided to go 5 lug, but being the cheapass I am I did it in parts. 5 lug in the rear came first since it was the easiest. ![]() ![]() I go to school in NC, so I decided to hit up some events in Charlotte. Streetwise drift has a points series or something, I just wanted seat time. ![]() ![]() We all stayed at a friend's house, this neat picture was taken there. ![]() After that I wanted to change the look of my car, so I went pignose front and got some chuki sides, as well as did some more drifting. ![]() ![]() ![]() ![]() ![]() ![]() Then I finally went 5 lug, 16x8 -10 Starion wheels all around ![]() ![]() ![]() In addition to my oil pressure problems I kept losing coolant. The head gasket was going, I decided to have it blow at the track. I got some new wheels somewhere in there too. First time my car had ever been on a trailer, it kinda sucked. ![]() ![]() ![]() ![]() ![]() ![]() Since my car was also my daily, I was out a method of transportation. Then came my daily, which I'm very thankful for. ![]() At this stage I decided on sticking with the KA and doing a top mount turbo setup. I thought about keeping my turbo and going top mount t2, but in the end I decided against it. I found what I thought was a good deal on a built KA, $1,000 for forged internals and less than 25 miles. Bought it, swapped random parts over, started it up, and of course it had rod knock. I ended up not even using that same engine when I built my own, just the rods. Shitty situation, should have just built my own engine and saved all that time and money. Bad engine: ![]() ![]() ![]() New built engine: ![]() I broke it in N/A and drove it around for a while before deciding to turbo it again. 550cc injectors, z32 mafs, and at the time a Holset HX30. I bought everything to make it work, almost had it running, then decided to go with another turbo. Sold the Holset and bought a Precision 5431 and "made" a new manifold for it. It's a bottom mount t2 manifold flipped and braced with a t3 flange welded on. ![]() ![]() ![]() Since it was finally running again I went drifting. Broke a coolant hose, other than that it went really well. I also put on my rear valance, I don't think it's an actual G-Grow, probably a replica. Either way it was in 3 pieces when I got it, I didn't bother fixing it at the time. I also got battles. ![]() ![]() ![]() Since the car was working I decided it was finally time for paint. A friend of mine found a post of mine from like 3 years ago saying I was going to paint it within a week, but obviously that didn't happen. I decided on a color(s) and started prep work. ![]() ![]() ![]() ![]() |
Got banned for a little while, couldn't finish my thread haha. Here's where I left off.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Since it was all painted it was time to go drifting again! ![]() ![]() ![]() At this point the car was running well so I decided to focus on suspension. I wanted to have correct suspension geometry so I had my knuckles modified. This gave me 45mm of front roll center correction as well as a lot more steering angle for drifting. ![]() ![]() I went to the Driftwater event in May, these are some pictures from that: ![]() ![]() More suspension bits, this time solid rear subframe bushings. These bushings also raise the subframe by 20mm which helps out suspension geometry. ![]() ![]() ![]() I just got back from another Streetwise event in Charlotte this past weekend. ![]() How it looked after that event. ![]() Plans were to keep drifting and having fun, but fate decided otherwise. Wastegate line blew off at an event. ![]() ![]() ![]() Ringlands blew on every piston. That was about 2 weeks ago, I've since gotten everything machined and almost back together. ![]() Hopefully it will be running again soon, I'm doing an HPDE at Carolina Motorsports Park on the 25th of August, then I have drift events on the 2nd and 15th of September. Thanks for reading! |
Nice I also enjoyed that bboy music in that vid and that female had nice legs in the passenger seat of yours.
Being a Floridian is a birth right! |
go SR20 its more reliable , i built a KA myself and 3 weeks into it it Blew , fixed it again.. ringlands blew again.. so now i know that going SR20 is way cheaper
![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
That's not always the case, it all depends on how its built and what stress you are placing on it. My buddy has had the same built KA for 5 years now and he has been running 23psi on a gt35r for the last 3 years with no problems at all. He has never opened up the engine once since he got it built. I blew up an SR twice, but it was just a bad machine shop...lesson learned.
https://instagram.com/eck_matthew/ |
![]() Join Date: Sep 2009
Trader Rating: (91)
![]() Feedback Score: 91 reviews
^This. There are so many more factors that play a major role than just building a motor. I don't care if you build an engine with titanium parts...if isn't tuned properly it'll still blow up.
www.monkeyboysyo.blogspot.com |
Engine specs are ARP everything, Cosworth head gasket, K1 rods, Wiseco 9:1 pistons. The one that blew was pretty much the same, only a Fel-Pro head gasket and OEM pistons. I've had some pretty bad luck with the KA, but I wouldn't go sr. The engine that blew was running perfectly fine, I just ran out of fuel and detonated when the wastegate line fell off. I'll have overboost protection this time around, as well as a -an wastegate line. If anything I'd do a jz swap, but I'm perfectly happy with the ka.
I've been at 6 psi for a while, recently put in a 10psi spring but blew the motor a few days after that. Based on similar setups it's probably around 300whp, plenty enough for the tracks I go to. My injectors will probably max out around 375whp so I might bump up the boost a little but later, but for now I'm happy at 10 psi.
Thanks, the car has definitely come a long way since when I first started haha.
![]() Got the engine all put back together today, still need to button up a few things before putting it in the car. I also need to get enough friends to help me carry it from the kitchen to outside haha. |
