Need Help!! sr20 Rocker arm piece's!!
Hey guys i just bought a 240sx with a red top sr20det its a just rebuilt motor i tryed starting it upu about a week ago and he had some werid nosie's so i took it to a mechanic and he said that the rocker arms are not on right and that are there missing these pieces shown in the pictures so i got some from a friend but i still need 6 of the ones with the groove and 3 more of them flat ones
they go under the rocker arm to hold them in place so dose anyknow know what they are called and or where i can get them?? sorry for the bad pic Last edited by Rac3rX; 05-13-2009 at 04:55 PM.. |
Hey thanks! i found them. but now to the next problem lol what size!! i read that you have to get a tool and messure each vavle i guess but is there any easier way to tell what size i need??
![]() Join Date: May 2008
The "rocker arm guides" are the shim with the groove. They come in only one size.
The shims are the flat one. They are used to adjust your rocker arm to be at the same height at each valve, so your rocker arm and cam lobe doesn't wear in angle. If you don't have the right shim, you might hear some noise coming from your engine head. I ordered mine there MyNismo.com - NISSAN SR20 Valve shims/shim guides See ya, Frank |
so dose each shim need to be a differnt size for that vavle?? or just messure one vavle and get all the same size?? and thanks for the help! mynismo is alott cheaper then all the other places i've found thanks!
No, they're all different at each valve!
Like I said, the grooved ones come in only one size, and the flat ones are used to get the rocker arm perfectly straight. So you'll need 8 grooved and 8 flat shim, and the flat will all be different size. you need to measure them to know which size you need. |
