![]() Join Date: Dec 2002
![]() ![]() Feedback Score: 1 reviews
tps question
what does it mean when my throttle reads 100% and voltage goes up to 4-5 when i unplug my tps? i am running s13 sr with auto harness.
Life is good in the bay. |
when i plug the tps back in, my % throttle goes to 0% and stays there no matter when im flooring the car or otherwise.. i measure the voltage directly from the ecu # 20 pin (throttle position) and it goes from .05 when im not on the throttle to .3 when im stepping all the way down.
car runs like shit i can start it but will die out after letting go of the gas when driving the car. when warmed up the idle will bounce from 800-1100.
![]() Join Date: Sep 2003
You have .3 volts at the ECU or the TPS? What are you getting at the TPS as far as voltage readings?
In search of a Zenki S14 right side (passenger) fender and straight hood that are rust free. |
![]() Join Date: Jan 2007
black wire should be a constant ground, green/red, or red wire should be 5 volts with the key in the ON position, then white wire should be 0 - 1.0 volt /w throttle closed and with the throttle wide open should be 4.0-5.0 volts. if not, replace with known good tps and continue diagnostics if necessary.
Dave |
No Limit Soldier.
![]() Join Date: Jan 2006
Where in norcal are you located?
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only" |
No Limit Soldier.
Aww shucks..a little far.
I would help you, only if you let me use your multimeter ![]() my shit is stupid wack.
