| South Western States Arizona, California, Hawaii, and Nevada. |
San Diego SR20 swap mechanic? Personal or shop?
Anyone know of a mechanic in san diego (individual or shop) that is good with SR20 swaps? I've got a swap, 95 percent done. In car, starts, runs but having issues getting it smoothed out/driving.
Thanks |
Car starts up slugishly. Takes about 8 cranks to fire. Despite being warmed up, it idles at 1600 RPM. Has a slight stutter/stumble when reving up. Took it for a test drive, car has no power, stutters and stumbles throughout RPMs but does not die. When clamping the idle air control valve vacume line after being warmed up, the car stalls(if that matters at all...that may or may not be normal...not sure).
San Diego Shops
There's always Drift Tech in Vista.
Drift Tech 635 Mercantile St Vista, CA 92083 (760) 945-0348 And Cartune Independent Service 7960 Ronson Rd San Diego, CA 92111 (858) 715-1804 Cartune is behind Pann Automotive and I had an engine swap done by them 10 years ago. Everything went fine. I haven't used Drift Tech, but I've heard that they are a small shop, but know what they are doing. I am thinking about taking my SR20DET small block in to have the pistons done there. Hope this helps. Both of those shops should be able to figure out your issue. They specialize in this kind of stuff. |
#9 | |
![]() Join Date: Feb 2003
Trader Rating: (289)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 289 reviews
you should make sure you are using a simple timing light, and not a super expensive digital one. otherwise your timing will be off. a cheapy from pep boys or something.
you should also check the wiring to your MAF, I would also check all your intercooler piping and vacuum lines. make sure everything is routed properly. there is a ton of information on the internet to help you trouble shoot it. unless you can afford paying someone everytime something goes wrong I have heard of a shop or 2 in san diego if you need more references, but i dont know them personally, i would go to corner 3 garage in lake forest or drift speed in los alamitos for my car. if you can drive your car and want some friendly help, you can come to the oceanside meet on thursday nights at 9pm. there is a thread for it.
![]() Quote:
check out shogun style performance or if youde like i can hook you up with cyrus martinez's number and you can ask him. Im sure he knows what the main issue woud be.
Isn't there a DEEPS garage in San Diego? (recently opened)
I heard Dads garage in lemon grove was good also. I always too my car to CanyonRacermotorsports in Mission Viejo, well worth the drive.
![]() Join Date: Apr 2007
Nobody knows what there doing your fkd!
How much for the car?
#/f/traderratings.html?u=57636 If i sold you something or gave you it for free post here! Thanks! |
