05-25-2008, 01:20 PM | #1 |
no ignition
help no spark at coil packs. replaced ignitor and cam angle sensor. car was running for awhile untill i started to mess around with cam angle sensor. had engine running then started to play around with cam angle sensor, engine just shutterd and turned off. heeeellllllllp if anyone has had this problem or not. need some kind of advise or lead.
05-25-2008, 09:19 PM | #2 |
Check main ignition power wiring by battery and ECU.. I assume you would'nt have two bad ignitors so... Check for bad coilpacks, shorted wiring harness, bad ecu.
Hope this helps. |
