![]() Join Date: Jul 2007
Trader Rating: (106)
Random S13 stuff! 5-speed, dohc, JDM markers, SR wiring...
S-13 ashtray w/NISMO badge
This is a clean S-13 ashtray with an old-school nismo badge mounted on it. It's nicely mounted and the badge is a nice detailed piece, NOT a sticker. SOLD! S-13 5-speed crossmember This is a clean, straight, S13 5-speed transmission crossmember. SOLD! S-13 lower shift boot This is a clean, complete, S13 lower shift boot assembly. Everything is included and un-damaged. Not oily or ripped! SOLD! Stock S-13 shifter assembly This is a 100% complete stock m/t shifter assembly off an S13. All springs, clips, bushings, etc... are included. It will fit any s-chasis tranny KA, CA, or SR. The shifter rubber boot is ripped, but otherwise the shifter is in good shape. $25 S-13 pop-up JDM front corner markers This is a set of 180sx front corner marker lamp housings. The housings are in decent shape, but not perfect. There are some small cracks and chips around the edges, mostly on the bottom where it's not visible once mounted. Unfortuanetly I do not have any light sockets for these, just the housings themselves. $20 S-13 DOHC throttle cable This is a stock S-13 KADE throttle cable. It is in good shape, smooth operation. This is needed for a KADE swap because the KAE one is shorter... SOLD! Redtop SR coilpack harness This is a stock redtop SR coilpack harness. All connectors are in great shape, SUPER CLEAN! $20 Redtop SR coolant temp sensor subharness This is the little subharness that goes from the main engine harness to the two coolant sensors. It is of a redtop SR and is in great shape just like the coilpack harness. $10 Last edited by racepar1; 01-23-2012 at 02:06 PM.. |
