![]() Join Date: Apr 2009
I used a Sikky Bar on my 1JZ into S14 swap. The kit is fantastic; all of the hardware is of very high quality. It is very sturdy and stout sway bar. However, I think that plays into its downfall. Because of its size I had pretty strong wheel interference with my knuckles. The bar had become the first point of contact prior to the tension rod.
This issue was alleviated some by widening the track width. Alas, I think it really depends on your desired use with the car. |
#4 | |
I believe the Whiteline sway bar is designed to work with Knuckles. Giving a little extra clearance.
Instagram @CheddarCheesus I hope you're offended |
