PSI PROformance Push to connect D.O.T vacuum/ boost kits
All in one package deal! 1/4" D.O.T air brake push to connect vacuum / boost kits. Everything you need to plum your turbo or vacuum lines with ease of quick disconnect to service your race car or street car and reconnect without leaks. Stainless steel fittings with high temp high impact d.o.t approved fittings and d.o.t air lines . Plum twin waste gates, boost solenoid, blow off valve, fuel pressure regulator, boost reference, and vacuum all in one package! Comes with straight & 90 fittings, 2 tees, and 12 feet of air brake line. 9 fittings total In stock and ready to ship or have the pro's at psi do your install *$85 picked up *$90 shipped *$75 w install
Dyno Tuning-Engine Swaps-Engine Building-Turbo Kits-Fabrication-General Repairs-State Inspection& Emissions-
PSIPROformance 200 w 5th St (Unit D) Lansdale Pa 19446 215-361-7100 www.psiproformance.com |
bump......
