#66 |
![]() Join Date: Jun 2009
^Thanks.
I am really excited to get the interior done. I should probably do kill switches, fire suppression, ignition button etc while its torn down. I might. |
#69 |
![]() Join Date: Oct 2008
Trader Rating: (131)
Wow, nice work! Pretty cool build for sure. My brother actually used to have an 05 Cooper S with a ton of JCW parts on it and Alta exhaust. It was a fun little car!
Excited to see progress on this thing! |
#72 | |||
Tally Racked up? is that total $ spent so far or what? sorry Im not good with new words ![]() |
#73 |
Great thread. Subscribed. Looks like I have to do a build thread for my car when it goes down in December to become a straight track car. Good luck and definitely keep us posted.
#80 |
^Thanks to all.
I will be working on it a bit tonight. Have a bad set of Extended studs that need replaced. Not sure if it was the spacer or the hub that caused the issue, but it is not good. Also I am hoping to start sanding down the floor to prep it for some paint. After that I want to starting going through the wire harnesses and cutting out the unimportant ones. |
#81 |
Spent the better part of Saturday smoothing out the interior with a wire brush. There are a few more spots I would like to get to still, but so far so good.
Also something else showed up to increase progress: |
#84 |
![]() Join Date: Nov 2010
making some serious progress man! gotta question about your gutted doors. what are you going to do about the windows if your going to run any at all?
89 2tone coupe 2jzgte swap in progress |
#85 |
^I am probably not running windows. The track I drive at does not allow windows up while on track so they aren't much more than dead weight regardless. I may make some clip in lexan windows to use when in the paddock/ pits though. Or Maybe just continue renting a garage at the track. Not sure?
#86 | |
![]() Join Date: Sep 2008
I'd take a look at the Works Bell Rapfix GTC for your setup... |
#87 |
I was looking at those but I know a few people that havehad them and told me the NRG hubs are just as reliable for less, so I ordered one yesterday actually.
If I hate it I will just sell it and go with the WB though. I was kind of in a rush to get something before we get going on the cage/ measuring it all out. |
#88 |
Awesome build, man.
May I offer a bit of advice? I had a car with a gutted interior, and I painted it black. Everytim eI drove it on a hot day, I was sweating like a hooker on cowboy payday. I resprayed it to a sort of off-white/grey color, and did the floor on the drivers side in black (so my dirty feet weren't quite as apparent) and it improved things considerably heat-wise. And seeing as hot you live in Utah, where it's hot 80% of the time.... Just my two cents. Otherwise, awesome build. I'll def have to follow this thread and see how it goes! Good luck!
#89 | |
Agreed. I am thinking por15 white inside. That or a black floor with orange cage, but I am leaning towards all white. |
#90 |
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() Feedback Score: 23 reviews
^^^ Orange cage would look sooo sekxay with that exterior color!!! Nice build!!!
[SIGPIC][/SIGPIC] http://wheelflip.com/r/Wheelwhore87 |
