Old 12-26-2015, 08:27 PM   #1
RIDrift
RIDrift is an unknown quantity at this point
SR SR20DET crank but no start (VIDEO)
Hey guys,
This is my first swap and I have hit a road block.
SR20det 89 240sx hatch
The starter is cranking over but the engine isn't turning over. It also makes a sound like the engine is releasing pressure. I've included a link to a Youtube video to help diagnose the problem.
https://youtu.be/z3aDPbQy96E
I've tried different batteries(Moved to the rear), checked continuity of wiring when cranking (When cranking the coil pack drop to 7.5-8 amps. is that normal?)
RIDrift is offline   Reply With Quote
Old 12-26-2015, 08:53 PM   #2
black'N'proud
black'N'proud's Avatar
black'N'proud is an unknown quantity at this point
Are you sure that the timing chain and cam angle sensor are correctly set? Could be as simple as that, good luck.
under cover brother
black'N'proud is offline   Reply With Quote
Old 12-26-2015, 10:41 PM   #3
Sileighty_85
Sileighty_85's Avatar
That "air" sound is the starter slipping.
Sound like your timing is off.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-27-2015, 09:52 PM   #4
RIDrift
Thank You!
I went out to the garage tonight and adjusted the timing and the CAS and it started right up. I appreciate the help!
240sx, crank no start, no start, sr20det
