![]() Join Date: Jun 2007
Changing directions a bit and selling off some of my rb26 parts. More Pics of everything available upon request. I do have all the paperwork on the cranknock (sold), rods, and pistons.
Rb26 Manley H beam rods:SOLD Brand new, never been out of the plastic, box only opened for pics. RB26 Wiseco Pistons 86.5mm 9:1 comp (custom spec):SOLD Brand new, only opened for pics. These are a set of custom spec'd pistons with the paperwork to prove it. They have added dome height for 9:1 compression and an additional oil retention land. These pistons were made to my request, they are not available off the shelf, and cost me over $900. Z32 Ecu converted for use with RB26: $50+shipping I used this on my last motor and it worked great. Allows you to run a single maf, blow through slot style if you like. ***Maf in picture is not included, and not for sale either*** RB26 no name fuel rail: SOLD Used, machined for 14mm top domestic style injectors. (standard nissan top feed stuff is 11mm) It can be run as a single inlet, single outlet, or dual inlet with single outlet. Mounts and fittings pictured are included Stock s14 6 bolt axles: $80+shipping 70k miles, great condition, just dirty and has surface rust. No rips in the boots, axle nut threads are straight. These are stock s14 3 prong, 6 bolt style
RB26 S14 Kouki
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
Don't say such things! I'll have cash in hand brother soon. This will nicely complete my setup so I can push some serious numbers! I'm choking my turbo at 500hp haha
Question on the piston and rods, what kind of fasteners do the rods have? What is the compression difference on those pistons, height, etc.. I have an R32 RB26 in an s13 and kinda wish you still had the crank especially if it was prepped with crank collar or whatever..
What was the direction you was going with this in your RB26? Do these rods and pistons need any supporting mods?? |
#15 | |
RB26 S14 Kouki
| rb25, rb26, s14, wiseco |
