Whistling/leaking noise?
Every time I hit boost and then let off the gas, my car makes a whistling noise following the sound of my BOV. Could this be a leak?
Here is a video: whistling - YouTube You may need to turn up the sound to hear it. The sound starts at :06 Also, my vac pressure is -22, as you can see in the vid. Is this normal? Thanks ![]() |
![]() Join Date: Sep 2005
You BOV is slow reacting
You should be pulling more vac than that when letting off the throttle, my guess is the gauge is maxed or you have a leak. At the end of the video sounds like you applied brakes and the gauge still read -22 although I have no idea if your gauge reads in mmhg, inhg or whatever just an observation.
#4 | ||
Thanks for the replies.
![]() Join Date: Nov 2007
Trader Rating: (33)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 33 reviews
my greddy type s used to do the same thing, it was really slow to close no matter now much i adjusted it but i later found that the welds around the flange were leaking lol
Ok thanks. What method would you suggest for diagnosing leaks? I am skeptical about spraying soapy water around my engine because there is a lot of wiring everywhere, which I don't want to short out.
#8 | |
Is the max vacuum reading 22inhg?. If so, than if you pull 25inch during decel it would probably only read 22inhg. Vacuum gauges vary in their readings, I look for at least a 30inhg vacuum gauge. Decel Vacuum is stronger than idle vacuum. Unless you have a cam upgrade, then it's way more stronger.
#9 | |
