Project kouki Fully built SR20DET +400hp on 91 Octane
.Price $12k Trade must be 2014+ ENGINE: Zenki S14 black top SR20DET Carrillo H-beam rods CP 87mm Pistons ARP Head studs ARP Main bolts ACL race bearings 1.5mm Tomei Head gasket 1mm Oversized valves Tomei 270 camshaft Supertech dual valve springs Circuit sports rocker arm stopper Tomei Oil pan Garrett GTX 3076R Twin Scroll Full Race Twin Scroll manifold Full Race Downpipe Biltz 3" Nuerspec exhaust Greddy Intake manifold Greddy top feed fuel rail ID 1000CC injectors Tomei N15 70mm Throttle body Tial Wastegate ATI Crank dampener Synapse BOV Walbro 255 intake pump Wiring Specialties Pro Engine Tranny Harness Nismo Thermostat Circuit sports FPR Tomei coil cover and oil cap GodSpeed Radiator with Nismo cap GodSpeed Intercooler Mishimoto oil cooler Mishimoto dual Electric fans with custom switch panel + OEM clutch fan ChaseBays coolant overflow tank Real Street performance-10 Billet Baffled Catch Can Odyssey Dry cell battery installed in the trunk ENGINE MANAGEMENT: AEM EMS w/ map sensor AEM Failsafe AFR with Boost Gauge MAC Boost Solenoid TRANSMISSION: 2006 Nissan 350Z CD009 transmission W/ custom bellhousing Transmission adapter plate Spec Clutch Mini Twin Disc ChaseBays clutch line Solid transmission mount One-piece aluminum driveshaft Kaaz 2way LSD Greddy Diff cover SUSPENSION: 326 power D1 spec Coilovers Megan racing- Front and Rear control arms Megan Rear lower toe arms Megan Rear upper control arm Megan Rear traction arms Megan steering bushing kit Megan Front and Rear sway bars SPL S14 outer tie rods Z33 inner tie rods Spare Megan outer and inner tie rods Rebuild power steering rack ISR Stainless Steel Power Steering Rack Lines ChaseBays Power steering system kit Nismo power brace Greddy front and rear strut tower braces SPL solid subframe bushings SPL Solid Diff bushings Solid engine mounts BRAKES: R33 front and rear R33 master cylinder P2M master cylinder heat shield Project mu D1 spec rear shoes Front and Rear Stainless-steel brake lines ChaseBays brake lines relocation kit INTERIOR: 2 Bride Vios Low Max seats 2 Bride seat rails 2 G-force 6-point harness+ OEM seat belts Cusco Safety 21 6-point bolt in roll cage Sparco R215 suede steering wheel NRG Hub and Quick release NRG 3 pieces cooling panel Speedhut water temp and fuel level gauges Custom A/C trim gauge pod Uncracked dashboard EXTERIOR: 2 set 5zigen 5-FN01R-C (17X9 +15 with federal tires) 2 set 5zigen 5-FN01R-C (17X10 +12 with federal tires) HID Headlights Front JDM bumper Rear JDM bumper Rear JDM valances JDM wing **Salvage CA title **Both front and rear OEM bumpers will be included **Deleted A/C. Deleted heater. Deleted sound deadening and rear seat. Cracked windshield. **Stock body with some dents, dings and oxidized paint. |
| 240sx, drift, nissan, sr20 |
