![]() Join Date: Aug 2003
Trader Rating: (35)
![]() Feedback Score: 35 reviews
need -an fitting size if available
Does anyone have the size of the flare fitting that goes into the z32 caliper on conversion lines? I have a set of lines with one fitting stripped and just need to find one. Guess i learned the hard way about over torquing the fitting
![]() Join Date: Sep 2004
how big are the lines? I'm pretty sure this is super easy to figure out.
#/f/tech-talk/53356-...-question.html especially if you searched. and then googling a/n fitting size chart. http://www.gre6.com/ansize and viola. you should have your answer. from that point forward if those few things are too hard to put together. the answer is -3.
Wayne |
| z32 |
