240sx Vk45de/Vk56de Swap kits????
Hey guys I dont think this has been discussed in other threads if so i haven't really gotten any good info on the subject. I want to swap a vk56de or a vk45de into my 1990 s13 hatch, and yes I know about the vh45de swap and swap kit but i do not want to use that motor. And i'm 100% sure i don't want to go ls1 so PLEASE don't tell me about it!!! I would really like to keep the nissan brand name and if it comes down to it i'll fab my own kit.
So with that said i would like to know who all has swapped these motors into there S-Chassis Swap Kits if there are any out there Aftermarket Support (I know it's limited) The Pros and Cons of both motors What transmission is best used with them Weight, ect.. Thanks in advance for the info guys! |
Try neo's garage he has adapter plates to use the 350z or 370z 6 speed to a vk56. He also has flanges to make custom headers too.
https://sites.google.com/site/neosgarage/ Problem I'm having is locating someone to do the harness(reason I choose a mechanical rate instead of an electrical rate for the navy I suck at the electrical part.) McKinney motorsports makes motor and transmission mounts for the 350z you might be able to chop out the old mounts and work with those. http://mckinneymotorsports.com/prod_VK56++350Z+swap Extrudabidy makes an itb setup Ryan kado runs these in his set up these with a set of cams put the car at 400hp and I think 400 tq http://www.extrudabody.com/servlet/t...VK56%2C/Detail |
Sr Motorcars makes a top end setup to rev to 9000rpm. Valves, springs, retainers the works.
SR Motorcars: Nissan VK56DE Engine Gtm motorsports does everything bottom end wise. Stock 98 mm bore pistons, 100mm bore pistons, bearings, high flow oil pump, and even a 6.0L stroker kit plus short blocks for stock 5.6L and 6.0L set ups.(FYI the 100mm pistons put the displacement up to 5777cc only 200cc short of the way more expensive 6.0L that's the way I'm going.) http://www.gtmotorsports.com/search....=search&page=1 Jim wolf does cams has for Chris foresburg and Ryan kado's car. They also do vk45de cams but I don't know much about that motor. Jim Wolf Technology website |
Thanks for the info Cody! Props for working with the vk56 thats what i'm probably going to do as well and are you going to do a build thread for your swap? I have the adapter plate already I will be using a friends 07 350z tranny because its the cheaper option and the 03-06 350z trannys are crappy. I will be looking for wiring harrness also well because that is not my strong suit either so i will let you know if i find anything
We're developing a line of VK56 parts so stay tuned. One of the first products in the works is a terminated wiring harness kit.
O do you know how much the weight of the vk56 is?
And vk45 is used in the Super GT races Nismo puts them in R-35's so thats saying alot! But i beleave they did bore them to a 5.0 that's why i was thinking about that swap but seeing that there the same block i think it will be same process for the swap. The Vk56 may be a taller do to the bigger stroke. That may be worth going vk45 to fit under the hood without cutting holes in it, I think the width is the same |
The intake manifold and oil pan are your major worries in fitting the VK56 into your S chassis.
We're addressing that. |
#9 | |
Great! Raw Brokerage Saves The Day! Keep me informed! And you will be making the oil pan baffled right? |
Our oil pans are always baffled
#11 | |
Nissan never fixed the problem, since the engine was already out of production by the time the problems manifested themselves, so to people still under warranty they just gave replacement engines, which will most likely end up doing the same thing. Hopefully the VK56 will prove to last a bit longer. |
#12 | ||
![]() Join Date: Sep 2005
Not to bump a week old thread. However I am working on this swap currently. Progress isn't super fast but if you have some more question pm me and I will attempt to help.
Facebook Link: https://www.facebook.com/brickhouseproductsllc |
Haha raw brokerage I'm the guy who keeps sending you messages every couple of months about when those parts are coming out. I bought those McKinney motor and trans mounts and the lexan windows you guys had on sale for my 350z during your moving sale. Is there an eta on when you guys are gonna be finished and what are you working on?
Just sent a message to z fever the other day they can do a harness for 350z's so everything runs like stock gauges and all. |
